AABEAR
Everything posted by AABEAR
  1. When I am pulling my fifth wheel I planed my stops so that way I start slowing down so it will cool down on it Owen. I will let it idle for about 2 mints then shut down.
  2. AABEAR replied to FiveNine's topic in Introductions
    Glad to have you on board
  3. My left front tire was wearing on the inside bad ball joint. So I jest replace the right one to. The wear looks good.
  4. LIKE MOPAR MAN said out board motor oil. I use 1/2 OZ per Gal with a sumer time mix of Howe's Diesel Treat the hole year.
  5. My 03 came with heated mirrors and seat's
  6. On some of the 99 and back they had this. They took heavy alum foil and wrapped the starter. You can look this up at TDR if you will. We had to do my boy 99. The transmission was removed 2 times then I found it at TDR and it worked. GOOD LUCK
  7. Your oil is a way to heavy. Out board oil is what most people use. I run 1/2 Oz per gal with Howes diesel treat.
  8. Sounds like you need a front end alignment
  9. Geno's has ATS for 470.25 three piece and a BD three piece for 508.25 these are pulse flow this helps to spool up the turbocharger faster. good luck
  10. Geno's has them also some steering box stabilizer Borgeson steering box also steering shafts You can get new or rebuild ons.
  11. My Jake came with it on the shifter looks like a 2 speed switch mounts on side of the shifter rod.
  12. the 241 to 273 will change your gears. I don't thank it will work if it was the same then it should work. Jest check the bolt pattern.
  13. I jest got a post card from RAM on the 53 block. So get a hold of them. GOOD LUCK
  14. A filter is cheper than an overhull. So I change my at every oil change. I pland on keeping this one from now on. Two tight and to old to geta new one.
  15. Go get you a good lawer that does personal Injured . They will take your clame if it looks good to them and they will take about 25% of what you get most does not have any charge only 25% of your take. GOOD LUCK
  16. I rember when they had oil bath filters. That would blow the oil out and make a big mess when they would run backward. Then a big clean up.
  17. I do not run all the time with it on. But when in town I run it on all the time when pulling my fifth wheel. I also use it to help warm the Eng up When on the HWY I turn it off till I am ready to exit. I allso use it in all gears.
  18. YOU might look for a pin hole in your return line. This has happen before it lets fuel drain back to the tank or on the ground it is a hard one to find. GOOOD LUCK
  19. You might check to see if you have a small leak in your fuel line. This has happen before or your fuel is draning back to the tank. GOOD LUCK
  20. DO NOT even look at it. Replace it every other oil change or every oil change it is cheap to change than to buy a new Eng.
  21. I have not had any trouble at all with outboard oil!! NOT even my JAKE brake. I run one oz per gal.
  22. Looks like you got a lot of fire wood in .
  23. Stay away from them.Jest buy the new good one from dodge or a parts house. == GOOD LUCK ==
  24. You might go to this wed site www.genosgarage.com They have some good ones. I have the piller post! But I wished I had gone with the dash mount. It is easer to see and you do not need to take your eyes off the road. == GOOD LUCK ==
