- Replies 15
- Views 5.8k
Mopar1973Man 3 posts
KATOOM 2 posts
01cummins4ever 2 posts
jokra 2 posts
Finally someone found the DOT laws on gravity fed tanks. Thanks to Pcarlson15 over on CF.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/2210985-cutting-up-bed.html#post25696489
GRAVITY FEEDING IS ILLEGAL
Here are some laws (regulations) which pertain to gravity feed fuel tanks, and why they are illegal.
1. 49 CFR CH.III (393.65) 6d; Gravity or syphon feeding is prohibited.
2. 49 CFR CH.III (393.67) 7.4.5.; Fuel withdrawal fittings. The fittings through which fuel is withdrawn from a tank must be located above the normal level of fuel in the tank when the tank is full.
In other words, the fuel must come from the top of the tank and not from a fitting on the bottom. For safety reasons. When in doubt, look at your factory tank.
There also the venting laws: FMVSS 301
1. Safety Venting System. A liquid fuel tank with a capacity of more than 25 gallons of fuel must have a venting system which, in the event of fire, will prevent internal pressure from rupturing the tank's body, or seams.
2. Each fuel tank must be equipped with a non-spill air vent (such as a ball check valve). The air vent may be combined with the fill-pipe cap or safetry vent.
ATTA tanks have a minimum of two sources of vents. Atta sending units come with an anti-siphon ball check valve vent and we use an OEM style pressure relief cap.
3. Fuel tanks must be clearly and permanently marked with the manufacture's name, manufacture date, gallon size, and must state "Meets all FMCSA requirements for non-side mounted fuel tank", and "not to exceed 95% of capacity."
And the fuel fitting and connection laws: VESC-22
1. The fuel connections from the auxiliary fuel tank to the primary system, including a selection control valve, shall not render inoperative any of the functions of the primary system. The auxiliary fuel tank lines, fittings, valves, and connections shall, for purposes of fuel flow, be of a size at least equal to the primary system.
Basically, No connections or selector valve can prevent the factory fuel system from working in normal functions from any part failure. if the selector valve fails, it cannot prevent the factory system from working. No portion of the selector valve or fittings shall be of smaller size than the factory fuel lines that might restrict fuel flow.
