- Replies 31
- Views 6.3k
Mopar1973Man 6 posts
KATOOM 6 posts
Me78569 5 posts
jlbayes 4 posts
Me either, but so far what I have learned when it comes to the VP44 generation trucks is that there is a TON of misleading information out there aimed at making a buck. I tend to be less
No. RV275 are the stock injectors used for the Cummins ISB for RV application. No. Still the RV series Cummins came with HX35 turbos. I'm still running 3" exhaust yet. My
Thus the reason why I didnt go with Chip's more expensive Special X either.
Ok so my slight miss at idle when fully warm is finally getting on my nerves. From my research it is most likely the injectors. I figure after 270K they need to be at least pulled and cleaned, and while doing this I may as well upgrade a bit. I am thinking of putting in RV275s. I do have a few questions that I could use some wisdom on as I have not played with injectors before.
1. Do I need to upgrade my fuel delivery system? Now don't throw stones at me but I still have the stock setup with the original injection pump. I have replaced my LP 3 times over the years and monitor my fuel pressure post filter with a mechanical gauge in the cab. Pressure is always 18 psi or greater at idle and I never dip below 10-12 psi at open throttle. I am not against upgrading the pump and lines however i do believe that the newer stock replacement LPs have come a long way since the original Carter pumps.
2. I have the stock turbo, don't think I will have to upgrade with this but thought I would ask anyways.....I do have an EGT gauge and 4" exhaust system so I am good there.
3. Valve Cover Gasket? I hear these are pretty solid. What are the chances of this needing replacement? Cost? Mine does have a little leakage over the years but nothing too bad.
4. Cross Over Tubes? Research has me feeling like my stock ones should work fine (engine serial number check is good) however I do feel that I need to replace the O-rings.
5. Injectors? Again I don't want to go too crazy but if you have an opinion let me know. My other thought is just to rebuild/clean the current injectors maybe upgrade the tips?? Has anyone done this. Seems like the crossover tubes might fit better with this option.
