2000 Dodge cummins 24 valve vaccum hose
- Replies 14
- Views 19.6k
Mopar1973Man 2 posts
Haggar 2 posts
Crushice 2 posts
portlandareae28 2 posts
The diagrams in the fsm and the descriptions in the parts manual are not helpful... 5/32" tubing and vacuum hose that fits 5/32 tubing is your friend. You have a funny connector or the
Several times I have accidentally pulled the line off of the vacuum pump while working on something else. You can use rubber vacuum line to splice a break in a pinch
For what it is worth I recommend just cutting the hard lines out. Leave enough on the pump end to serve as a nipple. Then order some silicone line from McMaster-Carr, Even vacuum hose from the par
hey guys I'm having an problem with my vacuum hose its all the way broken and now my cruise control stopped working and the ac is only blowing out of the defrost. i know this is coming from one of the vacuum hose just have and hard time trying to fix it or finding where i could get an replacement without having to go to the dealer cause we all know they are rip offs... any info would be helpful I'm in texas as the summer is here and its about to get hot...
