What water pump is worth a darn?
I put one on from parts store about around 260k ago. Don't remember which one. Just used whatever was on their shelf. I just replaced it when I did front seal a gear case reseal. Looked like it was just starting to weep so just replaced it. The replacement last as long as the oe.
I remember an article long time ago for my Honda Goldwing where silicate coolants would damage the water pump seal and cause the water pump to weep out the hole. As for me I've been using WalMart SuperTech or Prestone Coolant mixed 50/50 before loading the engine. Like I'm going to be due for a coolant change soon being all the miles I've racked up. Still no coolant leaks on my truck or water pump issues.
I am begging to think any silica bad.  Silica equals sand.  Arm and hammer tooth paste,  now have to use the prescription tooth paste until worn down gum grows back.  Chemical is si02. Used in auto glass to beach sand.
My gum  oem no longer around for replacement.:whistle:
