Got tired of elbow robbing on armrest especially on longer trips, desided to try some padding. First I used some packaging foam made out of plastic but it wore out in few weeks, so I got kids floor puzzle tile and cut it out of that, because it always comes out of it even after months of crap sitting on it. So I give you this, enjoy.... Thank me later, btw I used hot glue gun, worked perfect.IMG_20201002_172604.jpg.8ef1f967046aa65f2abac83f8c831756.jpg
  • Like 3
Dieselfuture, I'm serious when I answer your question about marketing those, for the third time, No I don't think you should call them 'Maxi Pads' Someone already uses that name I'm pretty sure. :poke:
  • Haha 3
Done wore the entire door panel and arm rest out on my truck years ago. I need to pull the fabric and replace it and add some padding below.
It would probably look better under fabric but I didn't want to waste much time on it, that's why I found a brownish color one and used marker on the edges. Was going to make it bigger but my elbow seem to be staying just in that spot, I may redo it later to make it more pretty.
Wore mine out so bad the gabric coated section seperated from the door panel.imcould not figure out a good way to reattach it. They are heat welded to each other. Found a new to me door panel for 50 bucks and bought it. My elbow wears in a different spot than the previous owner.
Center console from a 2013 Dodge truck.  Install in 20 minutes . . . . 3 cup holders.
Flat 'shelf' above the radiator . . . . stainless steel, rubber mounted.
Unable to insert photo.
Yeah I'm still looking for a different center console too, haven't seen one yet for decent price in good shape. This mod is for driver side door elbow padding.
