- Replies 55
- Views 10k
TFaoro 19 posts
Mopar1973Man 9 posts
AH64ID 5 posts
CSM 4 posts
Centramtics took care of my wheel balance issues
The centramatics are nice as you can reuse them for many sets of tires/wheels. They do take some grinding to make room but that isn't a big deal. It should work. You will pro
It seems to have started after it death wobbled 3 or 4 times. It wasn't after any parts or anything. Interesting you say that. After the last bad death wobble my axle seems to be sticking out
Alright guys I've got a vibration somewhere that I can't seem to find. It comes on at about 67mph and goes through 71. then fades up until 75 where it gets worse again. Above 80 it starts to fade.
Things I've done: All new U joints, tires balanced, checked driveshaft and all weights are still there, and the rear pinion is tight.
Any idea where I can look to find it??
