Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 351k
  • Quadzilla Power
    Quadzilla Power
I need to update my profile. I have dap150 10's and stock turbo. I am also having backdown pretty low in the rpms. I will try the above.......
only back down i have set it my egt at 1350* but on lvl 3 i didnt get a warning light showing that i hit that limit.
and remember. i only drive around on lvl3. when i want to let it loose then i bump it to lvl5.
i will put wiretap as low as possible and do a couple runs.
im confused on why canbus fueling wouldnt be maxed out regardless of wiretap as i thought they worked somewhat independently.
did you happend to see what the last part of the data log looked like when i had it on lvl 5?
if that graph is from one of the fitst two pulls (which im pretty sure it is as my boost is low and my egts arent high) then im not sure why canbus isnt maxed because i had it on lvl 3 with no wiretap
Edited by cumminsVP2001
Backdowns will pull canbua fueling to keep egts in check.
  • 4 weeks later...
hey guys, just got my dps 3 piece and 66/71 thrown on. did a few pulls with it and i can tell it is keeping egts lower, but i still get pretty hot if i go over lvl 3. my first pull i was on lvl 3 going up a slight hill and i never hit my defuel. lvl 4 and lvl5 i can pull longer than i used to but still get hot decently quick. thought? i figured this turbo is plenty for the fuel im pushing. im also spraying 100% water with all these passes.
@Me78569 i know there is probably alot of data in here, but can you see what these look like? i know i have one on lvl3 right away, then one on lvl 5, then one on level 4. your help is much appreciated
iQuad-2018-07-26-08.56.11679868457.csv
Who can tell me how the quadzilla *actually* changes fueling between lvl0 and lvl 5. I know about lvl1 ofcourse. But if I have an extreme tune, does level 0 completely take it off and all the levels inbetween are just a % of the fueling that my extreme tune calls for on the screen where you set all the fueling %'s. Does timing stay static across all levels, to wherever I set it? Asking bc I was towing with it this weekend.
Also what is the quadzilla policy or stance regarding timing when towing? I had mine set on max and took it out on the highway and got up to 45mph before I forgot to turn it down, whilst towing my 28' enclosed, but I wasnt aggressive on the pedal hardly at all.
Edited by rogerash0
Read through @Me78569‘s write up on the custom tuning and it has good recommendations for timing settings for different situations.
lvl 2 + timing is always the same
I towed on my "extreme" tune all the tune I never changed from it.
 I don't really get what level 2 is for I don't really get what level 2 is for, can't say I ever used it
lvl 2 is kinda of a mpg mode I guess.  It only allows for up to %100 oem fueling and will use 0-10 psi settings if below %100 in the tune.
I dont really get the point either, but I couldn't remove a feature
I'm always on lvl 2.  It's a nice cap for the truck to keep it at the DD power I want versus all the time, all the time.
:shifty:
 level 3 is where it's at:stirthepot:
Then if you need more to pass or whatever you got it ready, if you don't then I use go pedal for mpg :gun:
lol, considering level 3 for me is roughly the same power as my old 62/ 7x0.0095 combo on full wiretap, it's nice to be capped.  Also, I cruise around 10 psi of boost usually, so the fuel savings are real
It's just what compounds do.  If I'm lucky I can cruise at 5-7 psi
7 hours ago, Mopar1973Man said:
Try cruising at 2-3 PSI of boost.
Got you both beat at 1psi at 70mph
Is their any way to adjust idle timing? I have sac 7.010 injectors and I'm getting a pretty fair amount of white-ish haze at idle (hope that's normal?).... and I was thinking of I could add a degree or two of timing, at idle to offset the pop pressure and higher amount of fuel load, then maybe it would clean it up a little.
Nope.  Idle state is untouched
i haze pretty bad with my 7x12's
does anybody have dyno numbers with the quad? i am pretty impressed with what i put down.
527hp and 1072tq. i guess other guys who have dynoed before said this dyno was reading 50-100hp lower than what other dynos they used said.
on the street/track i dont get any kind of breaking up, but on my 2 dyno pulls right at the last second it popped a few times before the run was over. in my data logs my timing always maxes out at 30*, but like i said, never does it on the street really
My 7x.010’s don’t haze at all at idle as far as I know. At least with this 90°f weather, when it cooler out in the mornings it will a little. Now 0°F in the winter it’s a white smoke show while warming up ?
I'll try and catch a video of the amount of haze. It pretty much does it all the time. From cold start (at least 90* in the mornings) to operating temperature. They are DAP injectors with only 4000 miles. I hope I don't have one going bad already.
