Squeaky Clutch Pedal
- Replies 14
- Views 3.5k
KATOOM 2 posts
Buzzinhalfdozen 2 posts
deehammer 2 posts
sooxies 1 post
Thanks. I saw the Article written by @leathermaneod should have searched for that first. Looks like a pretty easy job just need to pick up 6 Bushings part # 04294639.
Just finished installing all 6 new bushings. Found them at a local dealer at $4 each. Took me about an hour once oriented it was pretty straightforward. Pedal has no sound now and is smooth as butter.
WD40 solved the squeak on my clutch pedal and fortunately it has not come back. It was a very very annoying sound to hear while driving. If it comes back I now know where to starting looking!
So when the weather starts to get a little cold outside my Clutch Pedal becomes squeaky when depressed. It is not the bearings or anything like that it is the pedal linkage itself. I have sprayed WD40 to up at the top of the pedal linkage connection but it doesn't seem to help or I am not hitting the right part. Anyone else experience this issue or have any insight? Everything functions fine it is just a little annoying. Seems I always have to find something to chase down on the rig.
