Push lock fittings with hose clamp
- Replies 23
- Views 8.1k
KATOOM 5 posts
JAG1 4 posts
dripley 3 posts
Royal Squire 2 posts
JAG if you ever want to be schooled.....I'd be happy to drive you through beautiful San Fransisco with these ol' Cummins trucks. Not only are you squeezing through narrow single horse streets but you
My family has a ongoing statement "count the lug nuts!" I have a cousin that was in law enforcement and he always said in accident investigations the one with the most lug nuts won.
Check Vulcan? I like hose clamps they make me feel good. Sub 50 I very much doubt they are needed, heck even 100 psi.
Looking for some fittings today on internet...
2 questions...
1. Any source for a 1/2 inch, 90 degree push lock fitting? Can't seem to find one. (2 wheel drive with a sump is getting pretty low to ground, try to keep line up much as possible)
2. Very many people use hose clamps on your push lock fittings? http://www.glowshiftdirect.com/1-2-Fuel-Line-Fuel-Pressure-T-Fitting-Adapter.aspx
