- Replies 34
 - Views 7k
								hodag56 8 posts
								Mopar1973Man 6 posts
								dripley 4 posts
								jlbayes 4 posts
Maybe maybe not. You need to get up under the front while someone turns the wheel back and forth and start looking for movement in all the parts connected to the steering box all the way out to the wh
After replacing my original box because of leaks and a bad bearing on the pitman shaft with a napa box ,I wish I would have rebuilt my original box .Even though those rebuilt boxes are warranteed does
I'm on my second reman box, technically 3rd since the PO had replaced it before. I replaced that one because it was leaking, but the new one had 1/2 turn of play. The one I have now causes the truck
Starting to make a list for my new to me 1999 3500 extra cab 4x4, and one at the top of the list is the steering. There is a half a steering wheel turn worth of slop to the left, and hardly any to the right.
Do you think the gear box needs replacing?
