Help with short Questions...
- Replies 43
- Views 7.2k
JAG1 15 posts
dripley 4 posts
jlbayes 4 posts
Mopar1973Man 3 posts
You guys are right. It's junk. What gets me is how people can take some green horn young guy that would become excited about the paint job and new tires and steal from the guy. I bet they'd be laughin
Dang I wish it was a 4x4, because I would not be able to get out of my road in winters. That's the only problem living out of the way in the foothills. Taking up the garbage each week the tractor is o
Not nearly the problems. They can have issues but normally shows up as low power first before damaging the injection pump.
I've realized that part of doing business is accepting whats available. Such as the nearly impossible 2nd gen 5 spd Trans on a fair priced truck. I found a very clean 2nd gen one ton dually, nearly perfect, it is priced right but, has the automatic trans.
My question is... do the one tons come with a better built trans? More reliable? It has 177 K miles.
It's a 1996.... are the front end problems the same as the 2002 trucks with trac bar and tie rods and BJs'?
I might add, it was a power company truck so it was regularly maintained and will check fluids, and how she runs in the morning.
