My addiction
So this is the truck that started my addiction. This is about what it looked like when I brought it home in 2010. It has had a few different turbo, injector and pump setups. I'll just give a quick run down of what they were and what the current is.
First setup (past stock) was a set of cpp 7x.010s, he351cw, tst pm3/diablo power puck/smarty, built auto, and ad II 165.
Next notable setup was a bit of a step up. s467.7, Infinite performance 6x.013s, tst comp/ts mvp, common rail cylinder head, same built auto and lift pump. All this time was on the original injection pump which I did not realize until I ppumped.
The day after the dyno I decided to ppump to meet my further goals. Only things I changed was the injection pump and cylinder head (common rail head does not have the clearance required for a ppump). Single best modification I have ever done to the truck. Less smoke and more power. I ran 3 different turbo chargers with the first 180hp pump. S467.7, S475 and finally a S472. At which point I decided I needed compounds. Dyno sheet is for the initial setup. A 180hp pump with 5ks & 024 dvs, same 6x.013s, same trans and same lift pump. With a bit of nitrous involved.
received_m_mid_1402584990873_ef0d5fa9465
And that brings us to the fun one. The compounds. The secondary (manifold) charger is a 66/68 with a .91 t4 housing. The primary is an S4T 86/110 with a 1.15 t6 housing. At this point I did purchase another ppump and sent it to Farrell Diesel to be benched. Transmission has been updated to a monster pump mike bolt together torque converter, larger input shaft and one of mikes outputs. I also stepped up to larger injector from Infinite. 6x.018s. It is a bit rowdy now lol.
  • Replies 147
  • Views 27.8k
    Thank you for that bit of information.
  • The last trans. builder wanted to upgrade the output for obvious reasons. I never broke it. The truck with vp on it went 7s in the 1/8th on a stock output.   A vp truck will not outflow the
  • Just some old steel wagon wheels and cooper at/3's (junk)     Yea a whole 2hp difference LOL
4 minutes ago, Me78569 said:
real men dyno then make excuses as to why the numbers are low
@TFaoro sound like any Duraturd owner we know?
It's a fuel pressure problem :lol:
:shifty: It made 500 right?
"It made 500. Promise.  Can't find the dyno sheet but it made it.  I swear it did."
We just happen to have a dyno this weekend. Only reason I am going. I am a bit leery of the track due to oil control issues lol and no drive shaft loops.
Sooooo.....no dyno this weekend. Had a shyte show of a Friday night.
Oh trust me. You can only get some many hints of you are not going to dyno before you pack it up. Down pipe fell off the 12v and tire blew on the trailer. That was on top of fixing trailer lights and finishing little stuff on the green truck.
Did the DP rust apart? :lmao: sorry couldn't resist!
ya know...cause Jacobs truck is rusty
12v you hooligans.....and no. One fell out and the other broke off. On my top 5 of weird shyte to break.
Soooooo injection pump is coming out and going to Texas lol.
1 hour ago, TFaoro said:
Whyyyyyyy?
two get bilt.  Duh.
I keep looking for that deal out my too. No success though.
Not the ones I want. Another dude in the group had a very nice set months ago....in Texas no less.
Did some work on the interstage piping Saturday. A buddy came over and welded this for me.
What's the copper coil in the background for? Very good welding, not hot or cold, just right.
It is for my drive pressure gauge. Coiled to help reduce heat before going into the gauge. Yes, it is much better than what I had done previously lol
