Fuel sumps are illgeal
  • Popular Post
Finally someone found the DOT laws on gravity fed tanks. Thanks to Pcarlson15 over on CF.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/2210985-cutting-up-bed.html#post25696489
GRAVITY FEEDING IS ILLEGAL
Here are some laws (regulations) which pertain to gravity feed fuel tanks, and why they are illegal.
1. 49 CFR CH.III (393.65) 6d; Gravity or syphon feeding is prohibited.
2. 49 CFR CH.III (393.67) 7.4.5.; Fuel withdrawal fittings. The fittings through which fuel is withdrawn from a tank must be located above the normal level of fuel in the tank when the tank is full.
In other words, the fuel must come from the top of the tank and not from a fitting on the bottom. For safety reasons. When in doubt, look at your factory tank.
There also the venting laws: FMVSS 301
1. Safety Venting System. A liquid fuel tank with a capacity of more than 25 gallons of fuel must have a venting system which, in the event of fire, will prevent internal pressure from rupturing the tank's body, or seams.
2. Each fuel tank must be equipped with a non-spill air vent (such as a ball check valve). The air vent may be combined with the fill-pipe cap or safetry vent.
ATTA tanks have a minimum of two sources of vents. Atta sending units come with an anti-siphon ball check valve vent and we use an OEM style pressure relief cap.
3. Fuel tanks must be clearly and permanently marked with the manufacture's name, manufacture date, gallon size, and must state "Meets all FMCSA requirements for non-side mounted fuel tank", and "not to exceed 95% of capacity."
And the fuel fitting and connection laws: VESC-22
1. The fuel connections from the auxiliary fuel tank to the primary system, including a selection control valve, shall not render inoperative any of the functions of the primary system. The auxiliary fuel tank lines, fittings, valves, and connections shall, for purposes of fuel flow, be of a size at least equal to the primary system.
Basically, No connections or selector valve can prevent the factory fuel system from working in normal functions from any part failure. if the selector valve fails, it cannot prevent the factory system from working. No portion of the selector valve or fittings shall be of smaller size than the factory fuel lines that might restrict fuel flow.
  • Replies 15
  • Views 6.6k
  • Sorry, this is a duplicate post from where I put it originally, but it applies to this conversation as well so wanted to get all of your opinions on it too...   I read over the DOT informati
I have never felt the need for one nor  the desire to cut a big hole in the bottom of my fuel tank even if they were legal.
7 hours ago, 01cummins4ever said:
@Mopar1973Man are you referring to the sump systems installed on bottom of tanks ?
Yes, these are illegal...
Image result for beans sump
Makes sense. Luckily I've got the draw straw.
GREAT thread.  I didnt think I ever had intentions to install a sump simply because of how all the tank crud will easily funnel directly into the fuel supply.....but now I know I wont.
I even looked up Transfer Flow just to see how they address this and directly from their website:
Caution
Gravity feed fuel systems may be easier to build and cheaper to buy, but does that mean it’s the smart choice? Due to safety, environmental, and legal concerns, Transfer Flow engineers will not endorse, promote, design, install, or sell gravity feed fuel systems. On gravity feed systems, if the valves, connectors, or fuel lines have any malfunctions there is nothing to stop fuel from overfilling the OEM tank and leaking all over the road.
Transfer Flow Auxiliary Tanks Are NOT Gravity Feed Systems. Our tanks are NEVER to be used in conjunction with gravity feed fuel systems.
Transfer Flow fuel tanks are NEVER to be used in conjunction with fuel tanks made by other tank manufacturers. Our tanks are only compatible with your stock OEM tank or Transfer Flow replacement tank.
I dont know if the links I posted are view-able or not but according to 49 CFR 393.65 6d. All fuel systems,, and 49 CFR 393.67 Liquid fuel tanks in the FMCSR manual, you would have to read it in its entirety to determine if its actually illegal.
It sounds like the op who posted that infro just cut bit and pieces from the original FMCSR rules and regs to promote the sale of a product in this case would have been ATTA Tanks. I am not promoting either draw straw or tank sump but after reviewing the rules it does not appear that a sump would be illegal, due to the fact it is not continually gravity fed to the injection system, its flow is cut off by the fuel pump, and it would make no difference if it were siphoning through a draw straw or gravity fed through a sump. If their was a break in the fuel flow line between tank and pump, even on a draw straw their would be nothing to stop the siphon effect until fuel supply runs out.
I'm not sure how our trucks fit into the FMCSR rules, but if they are engaged in any type of commercial use for hire like a hot shot truck, tow truck or welding rig with a dot #, they would be subject to all the rules and regs like the big rigs. Any way not to stir up any controversy but just my :2cents: on whats legal or not.
49 CFR 393.65 - All fuel systems.htm
49 CFR 393.67 - Liquid fuel tanks. _ US Law _ LII _ Legal Information Institute.htm
Here for the second posting...
Quote
§ 393.65 All fuel systems.
(a)Application of the rules in this section. The rules in this section apply to systems for containing and supplying fuel for the operation of motor vehicles or for the operation of auxiliary equipment installed on, or used in connection with, motor vehicles.
(b)Location. Each fuel system must be located on the motor vehicle so that -
(1) No part of the system extends beyond the widest part of the vehicle;
(2) No part of a fuel tank is forward of the front axle of a power unit;
(3) Fuel spilled vertically from a fuel tank while it is being filled will not contact any part of the exhaust or electrical systems of the vehicle, except the fuel level indicator assembly;
(4) Fill pipe openings are located outside the vehicle's passenger compartment and its cargo compartment;
(5) A fuel line does not extend between a towed vehicle and the vehicle that is towing it while the combination of vehicles is in motion; and
(6) No part of the fuel system of a bus manufactured on or after January 1, 1973, is located within or above the passenger compartment.
(c)Fuel tank installation. Each fuel tank must be securely attached to the motor vehicle in a workmanlike manner.
(d)Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector.
(e)Selection control valve location. If a fuel system includes a selection control valve which is operable by the driver to regulate the flow of fuel from two or more fuel tanks, the valve must be installed so that either -
(1) The driver may operate it while watching the roadway and without leaving his/her driving position; or
(2) The driver must stop the vehicle and leave his/her seat in order to operate the valve.
(f)Fuel lines. A fuel line which is not completely enclosed in a protective housing must not extend more than 2 inches below the fuel tank or its sump. Diesel fuel crossover, return, and withdrawal lines which extend below the bottom of the tank or sump must be protected against damage from impact. Every fuel line must be -
(1) Long enough and flexible enough to accommodate normal movements of the parts to which it is attached without incurring damage; and
(2) Secured against chafing, kinking, or other causes of mechanical damage.
(g)Excess flow valve. When pressure devices are used to force fuel from a fuel tank, a device which prevents the flow of fuel from the fuel tank if the fuel feed line is broken must be installed in the fuel system.
2
Quote
§ 393.67 Liquid fuel tanks.
(a)Application of the rules in this section. The rules in this section apply to tanks containing or supplying fuel for the operation of commercial motor vehicles or for the operation of auxiliary equipment installed on, or used in connection with commercial motor vehicles.
(1) A liquid fuel tank manufactured on or after January 1, 1973, and a side-mounted gasoline tank must conform to all rules in this section.
(2) A diesel fuel tank manufactured before January 1, 1973, and mounted on a bus must conform to the rules in paragraphs (c)(7)(ii) and (d)(2) of this section.
(3) A diesel fuel tank manufactured before January 1, 1973, and mounted on a vehicle other than a bus must conform to the rules in paragraph (c)(7)(ii) of this section.
(4) A gasoline tank, other than a side-mounted gasoline tank, manufactured before January 1, 1973, and mounted on a bus must conform to the rules in paragraphs (c) (1) through (10) and (d)(2) of this section.
(5) A gasoline tank, other than a side-mounted gasoline tank, manufactured before January 1, 1973, and mounted on a vehicle other than a bus must conform to the rules in paragraphs (c) (1) through (10), inclusive, of this section.
(6)Private motor carrier of passengers. Motor carriers engaged in the private transportation of passengers may continue to operate a commercial motor vehicle which was not subject to this section or 49 CFR 571.301 at the time of its manufacture, provided the fuel tank of such vehicle is maintained to the original manufacturer's standards.
(7)Motor vehicles that meet the fuel system integrity requirements of 49 CFR 571.301 are exempt from the requirements of this subpart, as they apply to the vehicle's fueling system.
(b)Definitions. As used in this section -
(1) The term liquid fuel tank means a fuel tank designed to contain a fuel that is liquid at normal atmospheric pressures and temperatures.
(2) A side-mounted fuel tank is a liquid fuel tank which -
(i) If mounted on a truck tractor, extends outboard of the vehicle frame and outside of the plan view outline of the cab; or
(ii) If mounted on a truck, extends outboard of a line parallel to the longitudinal centerline of the truck and tangent to the outboard side of a front tire in a straight ahead position. In determining whether a fuel tank on a truck or truck tractor is side-mounted, the fill pipe is not considered a part of the tank.
(c)Construction of liquid fuel tanks -
(1)Joints. Joints of a fuel tank body must be closed by arc-, gas-, seam-, or spot-welding, by brazing, by silver soldering, or by techniques which provide heat resistance and mechanical securement at least equal to those specifically named. Joints must not be closed solely by crimping or by soldering with a lead-based or other soft solder.
(2)Fittings. The fuel tank body must have flanges or spuds suitable for the installation of all fittings.
(3)Threads. The threads of all fittings must be Dryseal American Standard Taper Pipe Thread or Dryseal SAE Short Taper Pipe Thread, specified in Society of Automotive Engineers Standard J476, as contained in the 1971 edition of the “SAE Handbook,” except that straight (nontapered) threads may be used on fittings having integral flanges and using gaskets for sealing. At least four full threads must be in engagement in each fitting.
(4)Drains and bottom fittings.
(i) Drains or other bottom fittings must not extend more than three-fourths of an inch below the lowest part of the fuel tank or sump.
(ii) Drains or other bottom fittings must be protected against damage from impact.
(iii) If a fuel tank has drains the drain fittings must permit substantially complete drainage of the tank.
(iv) Drains or other bottom fittings must be installed in a flange or spud designed to accommodate it.
(5)Fuel withdrawal fittings. Except for diesel fuel tanks, the fittings through which fuel is withdrawn from a fuel tank must be located above the normal level of fuel in the tank when the tank is full.
(6) [Reserved]
(7)Fill pipe.
(i) Each fill pipe must be designed and constructed to minimize the risk of fuel spillage during fueling operations and when the vehicle is involved in a crash.
(ii) For diesel-fueled vehicles, the fill pipe and vents of a fuel tank having a capacity of more than 94.75 L (25 gallons) of fuel must permit filling the tank with fuel at a rate of at least 75.8 L/m (20 gallons per minute) without fuel spillage.
(iii) For gasoline- and methanol-fueled vehicles with a GVWR of 3,744 kg (8,500 pounds) or less, the vehicle must permit filling the tank with fuel dispensed at the applicable fill rate required by the regulations of the Environmental Protection Agency under 40 CFR 80.22.
(iv) For gasoline- and methanol-fueled vehicles with a GVWR of 14,000 pounds (6,400 kg) or less, the vehicle must comply with the applicable fuel-spitback prevention and onboard refueling vapor recovery regulations of the Environmental Protection Agency under 40 CFR part 86.
(v) Each fill pipe must be fitted with a cap that can be fastened securely over the opening in the fill pipe. Screw threads or a bayonet-type point are methods of conforming to the requirements of paragraph (c) of this section.
(8)Safety venting system. A liquid fuel tank with a capacity of more than 25 gallons of fuel must have a venting system which, in the event the tank is subjected to fire, will prevent internal tank pressure from rupturing the tank's body, seams, or bottom opening (if any).
(9)Pressure resistance. The body and fittings of a liquid fuel tank with a capacity of more than 25 gallons of fuel must be capable of withstanding an internal hydrostatic pressure equal to 150 percent of the maximum internal pressure reached in the tank during the safety venting system test specified in paragraph (d)(1) of this section.
(10)Air vent. Each fuel tank must be equipped with a nonspill air vent (such as a ball check). The air vent may be combined with the fill-pipe cap or safety vent, or it may be a separate unit installed on the fuel tank.
(11)Markings. If the body of a fuel tank is readily visible when the tank is installed on the vehicle, the tank must be plainly marked with its liquid capacity. The tank must also be plainly marked with a warning against filling it to more than 95 percent of its liquid capacity.
(12)Overfill restriction. A liquid fuel tank manufactured on or after January 1, 1973, must be designed and constructed so that -
(i) The tank cannot be filled, in a normal filling operation, with a quantity of fuel that exceeds 95 percent of the tank's liquid capacity; and
(ii) When the tank is filled, normal expansion of the fuel will not cause fuel spillage.
(d)Liquid fuel tank tests. Each liquid fuel tank must be capable of passing the tests specified in paragraphs (d)(1) and (2) of this section. The specified tests are a measure of performance only. Alternative procedures which assure that equipment meets the required performance standards may be used. .
(1)Safety venting system test -
(i)Procedure. Fill the tank three-fourths full with fuel, seal the fuel feed outlet, and invert the tank. When the fuel temperature is between 50 °F. and 80 °F., apply an enveloping flame to the tank so that the temperature of the fuel rises at a rate of not less than 6 °F. and not more than 8 °F. per minute.
(ii)Required performance. The safety venting system required by paragraph (c)(8) of this section must activate before the internal pressure in the tank exceeds 50 pounds per square inch, gauge, and the internal pressure must not thereafter exceed the pressure at which the system activated by more than five pounds per square inch despite any further increase in the temperature of the fuel.
(2)Leakage test -
(i)Procedure. Fill the tank to capacity with fuel having a temperature between 50 °F. and 80 °F. With the fill-pipe cap installed, turn the tank through an angle of 150° in any direction about any axis from its normal position.
(ii)Required performance. Neither the tank nor any fitting may leak more than a total of one ounce by weight of fuel per minute in any position the tank assumes during the test.
(e)Side-mounted liquid fuel tank tests. Each side-mounted liquid fuel tank must be capable of passing the tests specified in paragraphs (e)(1) and (2) of this section and the test specified in paragraphs (d)(1) and (2) of this section. The specified tests are a measure of performance only. Alternative procedures which assure that equipment meets the required performance criteria may be used.
(1)Drop test -
(i)Procedure. Fill the tank with a quantity of water having a weight equal to the weight of the maximum fuel load of the tank and drop the tank 30 feet onto an unyielding surface so that it lands squarely on one corner.
(ii)Required performance. Neither the tank nor any fitting may leak more than a total of 1 ounce by weight of water per minute.
(2)Fill-pipe test -
(i)Procedure. Fill the tank with a quantity of water having a weight equal to the weight of the maximum fuel load of the tank and drop the tank 10 feet onto an unyielding surface so that it lands squarely on its fill-pipe.
(f)Certification and markings. Each liquid fuel tank shall be legibly and permanently marked by the manufacturer with the following minimum information:
(1) The month and year of manufacture,
(2) The manufacturer's name on tanks manufactured on and after July 1, 1989, and means of identifying the facility at which the tank was manufactured, and
(3) A certificate that it conforms to the rules in this section applicable to the tank. The certificate must be in the form set forth in either of the following:
(i) If a tank conforms to all rules in this section pertaining to side-mounted fuel tanks: “Meets all FMCSA side-mounted tank requirements.”
(ii) If a tank conforms to all rules in this section pertaining to tanks which are not side-mounted fuel tanks: “Meets all FMCSA requirements for non-side-mounted fuel tanks.”
(iii) The form of certificate specified in paragraph (f)(3) (i) or (ii) of this section may be used on a liquid fuel tank manufactured before July 11, 1973, but it is not mandatory for liquid fuel tanks manufactured before March 7, 1989. The form of certification manufactured on or before March 7, 1989, must meet the requirements in effect at the time of manufacture.
(4)Exception. The following previously exempted vehicles are not required to carry the certification and marking specified in paragraphs (f)(1) through (3) of this section:
(i) Ford vehicles with GVWR over 10,000 pounds identified as follows: The vehicle identification numbers (VINs) contain A, K, L, M, N, W, or X in the fourth position.
(ii) GM G-Vans (Chevrolet Express and GMC Savanna) and full-sized C/K trucks (Chevrolet Silverado and GMC Sierra) with GVWR over 10,000 pounds identified as follows: The VINs contain either a “J” or a “K” in the fourth position. In addition, the seventh position of the VINs on the G-Van will contain a “1.”
[36 FR 15445, Aug. 14, 1971, as amended at 37 FR 4341, Mar. 2, 1972; 37 FR 28753, Dec. 29, 1972; 45 FR 46424, July 10, 1980; 53 FR 49400, Dec. 7, 1988; 59 FR 8753, Feb. 23, 1994; 69 FR 31305, June 3, 2004; 70 FR 48053, Aug. 15, 2005; 78 FR 58484, Sept. 24, 2013]
I believe the main concern here is if in a wreck what's going to happen. Obviously you have fail safes to shut off fuel via lift pump power and what not. So I'm a wreck with no power to the lift pump, if a line broke coming from a sump, there's nothing from stopping that fuel from flowing and doing its job of 'gravity feed' to wherever that line broke. With a drawstraw, if any line gets broken, sure it'll drain whatever fuel was in those lines but once it's out there's not more fuel coming out since it's being pulled from the top of the tank.
Edited by notlimah
  • 4 weeks later...
I read over the DOT information, and came away with the conclusion that sumps are perfectly legal. Here are the details on what I found. Please correct me if I read any of this wrong, as I do really want to understand this, but I couldn’t find anything in here that tells me a sump on the bottom of a diesel tank is illegal on these trucks:
https://www.gpo.gov/fdsys/pkg/CFR-2011-title49-vol5/pdf/CFR-2011-title49-vol5-sec393-67.pdf
Regarding 393.65:
The “gravity or syphon feed prohibited” absolutely does NOT apply to our trucks. This is clearly taken out of context by that one website and only relates to feeding directly into the carb or injector.
  • (d) Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector.
Furthermore, down a little ways in the fuel lines section it even references a sump and the fact that any fuel lines which are more than 2” below the tank or the sump need to be protected:
  • (f) Fuel lines. A fuel line which is not completely enclosed in a protective housing must not extend more than 2 inches below the fuel tank or its sump. Diesel fuel crossover, return, and withdrawal lines which extend below the bottom of the tank or sump must be protected against damage from impact.
Regarding 393.67:
And then regarding anything found in 393.67 – this does not apply to most personal trucks, unless you are using it commercially. It states at the beginning of 393.67 that these rules are for commercial motor vehicles, as opposed to 393.65 which states just “motor vehicles”:
  • (a)    Application of the rules in this section. The rules in this section apply to tanks containing or supplying fuel for the operation of commercial motor vehicles or for the operation of auxiliary equipment installed on, or used in connection with commercial motor vehicles.
Even if we did have to conform to 393.67, rule #4 under construction of tanks shows that a drain or bottom fitting must not extend more than ¾” lower than the tank or sump. There again it references a sump as a valid option.
  • (4) Drains and bottom fittings. (i) Drains or other bottom fittings must not extend more than three-fourths of an inch below the lowest part of the fuel tank or sump.
And then #5 shows us that diesel tanks are exempt from the requirement that fittings be located above the normal fuel level, so that one doesn’t apply to us either.
  • (5) Fuel withdrawal fittings. Except for diesel fuel tanks, the fittings through which fuel is withdrawn from a fuel tank must be located above the normal level of fuel in the tank when the tank is full.
Less worried about diesel than I'd be about gas. I'm sure that the complete tank emptying of fuel is better than with a suction system. I ran mine dry at 30 gallons going up a hill. 5 gallons left in tank.
