- Replies 18
- Views 9.1k
Mopar1973Man 3 posts
Dieselfuture 3 posts
99dodge_pos 3 posts
JAG1 2 posts
Popular Days
No offense taken Dieselfuture. God is great and life is good!
It takes years of knowledgable folks posting on a good site like this to compile what to do for reliability and longevity. I thank even the newbie folks as well for contributing.
Yes it can that's why you would want to do this. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/59_fuel/installing-protective-lift-pump-relay-r501/
Changed fuel filter cracked line bled system tightened line started truck fuel pressure came up then 3 seconds later it went to zero shut truck off. Checked for air lock then voltage and founds 2 volts output from ECM called air dog they instructed me to wire to 12v switched and this is common. Tried that all issues resolved for now.... Had to leave for a trip so I decided to run it hooked as such truck performed as expected that was a week ago.
My issue is this does that mean the ECM is failing is there a way to find out I have never had one sign of ECM issues until now
Second is I often use the trucks radio when parked in ACC. and the fuel pump continues to run any suggestions on where to wire the pump to?
