- Replies 31
- Views 9.5k
Mopar1973Man 8 posts
JAG1 5 posts
joecool911 5 posts
bcbigfoot 4 posts
Batteries resist charge when cold. So the battery temperature sensor under the driver side battery detects the battery temperature and adjust the charging rate for the battery temperature. So on a col
Depends on which alt., there are two different makes the Bosch and the Denso. The Denso has bolted in Diodes and the Bosch which I have, the diodes are welded in (possibly soldered in) not easy to c
No. It's easy just pull the back cover off and the diodes are held in place with Phillips screws. While your there you can change the brushes too.
My alternator output is less when warm out than when cold. Now it’s putting out 14.3 on average. When it’s hot it’s more like 13.7. Is this an indication of trouble ahead?
