- Replies 27
- Views 10.6k
Marcus2000monster 5 posts
Mopar1973Man 3 posts
dripley 3 posts
notlimah 3 posts
First time I did injector work I created a nasty random miss. No external leak and a random hard start. After talking to some of the guys found out I installed then wrong. So I re-did my install exact
Great minds think alike.
To check torque on hold down bolts on the ones you're not going to be messing with you can retorque them when hold Downs for injectors are out. Same 89in/lb I went 90 can't be that picky, those bolts
So injectors are currently getting re-popped to 325 and I've been watching youtube vids and write up on injector swaps. Obviously everyone does it a little different but I want to make sure I get things straight for my particular situation. As far as I know I'll be pulling on stock injectors and I don't know if/when a valve lash adjustment was done.
When swapping injectors do I need to remove the exhaust rocker arms? Most videos show them being removed and I'm wondering since I don't think these injectors have ever been out of the truck if that'd be a good idea in order to verify the torque spec on the rear injector hold down bolt?
I want to make sure I get the order correct when installing the new injectors. Seems it should..
-install injector with crossover tube hole facing towards crossover tube (lubing o-ring and washer with oil or vaseline)
-make sure injector is seated, should feel/hear slight pop once seated correctly
-install crossover tube, should feel/hear slight pop, verify crossover tube is sitting flush with head (lubing o-ring with oil or vaseline)
-tighten injector hold down plate (89inlbs for both???)
-again verify crossover tubes are seated and tube is flush with head
-installed fuel lines over crossover tube (25ftlbs???)
Anything else??
Edited by notlimah
