To replace my VP44 or no to
- Replies 25
- Views 4.9k
trreed 6 posts
Marcus2000monster 5 posts
dripley 4 posts
Dieselfuture 2 posts
Popular Days
Yep not having to worry is a big thing. Said hell with it pull trigger on Thoroughbred VP and got a new pushrod cover gasket. Figured wile I'm in there might as well bc my reading has show
Don't forget a good mechanical fuel pressure gauge if you don't already have one. Then you can monitor fuel pressure to stay above the critical 14 p.s.i. level. Make certain new VP got a n
@Dieselfuture In how the serial number on the pump ends. 027 is SO, 028 is HO, and 029 is industrial application, I agree with this. My truck doesn't like that oil either.
So I'm bored here at work thinking deep, Have 206k on my 01, factory VP.
Im second owner, bought at 120k miles December of 2015. Previous owner hauled camper to Florida and back and maintained it with regular oil and filter changes all documented.
First thing I did was on my way home order a Air dog rapotor factory replacement. 2 days later it showed up and ran fleetguard fs19855 filters with 5k miles changes. That pump died in August of 2017.
Then a Fass titanium 165 was put on and I ran the factory Fass filters for 11k miles and am doing 15k mile changes on fleetguard fs1000 and CAT IR0750.
And every oil change I buy a 16oz silver bottle of Power Service n run it through accordingly. Then in winter I run the white bottle power service stuff pretty much every fill up. Oh and I'm pretty good about draining water separator.
So my question is, should I as preventive maintenance replace my VP44. I plan of getting a 2 year warranty one from Thoroughbred diesel. Living in Wyoming and my lifestyle and job putting me in remote places and on the road alot being stranded isn't a option. I've done reading and found some older post on various sites. The post are mixed with lots of my electronics died at 30k and my factory one lasted 400k. So do I gamble on my Uber anal maintenance getting me high milage or do I just replace it? Thanks
