Powder Coating Wheels
  • Replies 27
  • Views 6.8k
23 minutes ago, Blueox01 said:
Anyone ever have their factory wheels powder coated?
No but third gen alloys look awesome on our trucks!
My truck has a couple extra wheels
I can get all 7 blasted/powder coated for around $300
I had 2 sets of the factory but they all started cracking. Going to find a set a 4th gens one day.
Steel wheels cracking?
Sorry, I had the alloy wheels.
Never powder coated any. That would be nice. Maybe if I had an extra set so my vehicle wasn't down while being done. I've Plasti-coated a few sets. Turned out great and is easy to touch up if damaged.
Just curious . . .
Wondering why the fascination with 17 - 18 - 20" plus wheels ?
The OEM 16" seem to work well . . .
I love my 16's. I do like the 4th gen not so much for the size as the look. 16's are a bit cheaper than 17's and bigger also. I also had trouble finding 16's with the right offset for the Dodge.
2 hours ago, Macarena Man said:
Just curious . . .
2
The only reason I can see jumping to 17-inch is for the 3rd Gen oversized brakes. But if your using the 245's like I'm running you have better final gear ratio and better braking than upgrading to 17-inch wheels and oversized sizes. I jumped back to the 2nd Gen steel chrome wheels (16 x 6) which happen to be 1 inch narrower than the aluminum wheels (16 x 7). Most people look for the cool factor and go oversized. I stuck to the performance and calculation of gear ratio and torque output. Now I actually hunt for the big jacked up 37" tires because I can whip them with no problem. Done it more than once. Funny when a small tire stock height 2nd Gen whips a 4th Gen jacked up on 35" inch tires. :burnout2:
IMG_3702.jpg.4359a4704d87a589c0de8b528b5f412b.jpgYes.  Factory 4th gen's but not 2nd.49585217013__C0EDB22D-997D-4680-84DB-A840D5C4D050.JPG.d28bbb6ae293ea8551512597e66750f0.JPG
Edited by sooxies
8 hours ago, Macarena Man said:
Just curious . . .
running 3rd gen brakes
I never powder coated the wheels on these trucks but I did about 20 years ago on an older 4wd I have.  I took the American Racing Outlaws and had a shop bead blast the clear coat off and then powder coat them white.  They looked amazing...  Back then it only cost me a couple hundred bucks too.  I have no idea if I could get someone to do all that today for that kinda money.
My cost was $60-65 per wheel (can't remember exactly...that ballpark) for blasting and coating.
That doesn't seem so bad....
No, thats not bad at all...  Especially when you see people spend over a couple grand for wheels. :duh:
The guy I found to do it about $400 for all them. Gunmetal Gray
That's pretty pricey.  There's not much competition where I am either so it wasn't a situation where a single business can charge whatever they want.
