- Replies 151
- Views 17.6k
Marcus2000monster 46 posts
Mopar1973Man 23 posts
Dieselfuture 16 posts
dripley 12 posts
Never hook the fuel pump to the battery. Hook it up in the power stud in the PDC. I wish both AirDog and FASS would remove that from the manual. That is the dumbest thing I've heard was t
So this issue you're having. Your title says extended crank but later on you say slow crank. 2 very different things. Which is it? I've had extended crank issues twice. Once was an IP that was just wo
That's as close to stock as you can get. Make sure they are the Bosch RV275 and not some cheap knock off junk. I bought mine from DAP last spring.
Developed a new issue. Usually my truck will start with half a revolution. It has started taking 4 sometimes more to start. What’s going on? No codes truck runs good. Good fuel pressure.
