- Replies 25
- Views 6.4k
LorenS 6 posts
dripley 5 posts
Mopar1973Man 3 posts
JAG1 3 posts
I missed the part about the Allison, thought he was speaking of a manual.
I understand. Look for the power distribution center.ground... it's important. looking down in front of the drivers side battery, down on the flat part of the fender (kind of way down in there) there
trreed, no I have not. But I will tomorrow! Agreed. I have three more battery terminal to replace (already did one), and the G100 ground under the passenger battery I know needs attent
No run/start power. Accessories position works. Timer module(?) under dash ticks about 4 times per second when door is open. No fuses seem blown, though we all know that means nothing.
Sitting outside kid's baby sitter's house so any help appreciated!
Have not had any prior issue with switch, behaves as brand new.
Even the headlights don't work, but batteries are juiced.
Under hood light works great, hitting hazards sounds like a cheap fart machine by emergency brake pedal. No brake lights.
Changed out 50 amp Battery fuse, no help.
