- Replies 211
- Views 34.5k
dripley 65 posts
Dieselfuture 26 posts
Blueox01 20 posts
AH64ID 18 posts
Pile it on boys, I dont care. After 3 minutes of priming and 5 minutes of on an off starting, SHE IS ALIVE AND PURRING LIKE 24V. Test drive after lunch.
I don't know you that well, so I would never treat you like others do. When you are done, are you going to put the roof back on the chicken house? - John
I finally got started on this in earnest today. Did a little on it Monday pm. Then today after the morning mist died away and I got the doctors appointment out of the way the fun began. Itwent pretty well. Not one ceased bolt. They all came out nicely. Made this far today.
My helper.
The offending leak. The oil is from some bad pouring out of the gallon jug.
Now a couple questions.
Those metal strips between the pairs bolts at the front and rear of the exhaust manifold, are they necessary to reinstall? I thought they were under the bolt heads until I destroyed them all and realized they were over the bolts. They appear to keep the bolts from backing off? I will have to find some if necessary.
The exhaust manifold gaskets have raised area on one side, does this raised portion go to the block or the manifold?
This arrived yesterday.
Hope to have the head off and to the machine shop tomorrow. More to come.
