Head gasket replacement
 I finally got started on this in earnest today. Did a little on it Monday pm. Then today after the morning mist died away and I got the doctors appointment out of the way the fun began. Itwent pretty well. Not one ceased bolt. They all came out nicely. Made this far today.
20190326_181418.jpg.2ea990b9a228f68b51876a092f285210.jpg20190326_181437.jpg.8ba86fe8771b9fa69cf1f59caf56e836.jpg20190326_195807.jpg.a3098e9c507cf9674b2f9e4c87d6b8ed.jpg
The offending leak. The oil is from some bad pouring out of the gallon jug.
Now a couple questions.
Those metal strips between the pairs bolts at the front and rear of the exhaust manifold, are they necessary to reinstall? I thought they were under the bolt heads until I destroyed them all and realized they were over the bolts. They appear to keep the bolts from backing off? I will have to find some if necessary.
The exhaust manifold gaskets have raised area on one side, does this raised portion go to the block or the manifold?
This arrived yesterday.
Hope to have the head off and to the machine shop tomorrow. More to come.
  • Replies 211
  • Views 45k
  • Pile it on boys, I dont care. After 3 minutes of priming and 5 minutes of on an off starting,       SHE IS ALIVE AND PURRING LIKE 24V.     Test drive after lunch.
  • Dieselfuture
    Dieselfuture
  • Tractorman
    Tractorman
    I don't know you that well, so I would never treat you like others do.  When you are done, are you going to put the roof back on the chicken house?   - John
10 hours ago, Blueox01 said:
Imagine that!  So the gasket compressed as you did step 1&2 and you "re-checked torque" to make sure it was right PRIOR to the final 90* torque. But you had more movement on re-check at the center and less going out, right?
Not sure why you are surprised :lmao:
It's a perfectly fine procedure for a stock powered truck.
Edited by AH64ID
3 hours ago, NIsaacs said:
Are you missing a soft plug on the front of the head, or does it just look that way?
The one at the center of the 40 bolt holes facing front? It is there you can see the edge of it in picture.
3 hours ago, JAG1 said:
Dripley, remember...... ''slow and deliberate'', so no loose ends each step of the way. You don't want to skip something just so you can hear it run by evening boss. I know how it is when your so close to get your wings flapping again. :thumb1:
I have been my slow and deliberate self on most of this. But I am getting to things I have done already and hope it speeds up a bit just from familiarity. I want to hear it run for sure. But it is getting in and out of wifes saturn thats killing me. I had to go get the head in it and it felt like there 2 full size passengers riding with me.
It compressed at each step. I have to admit it compressed more than I thought it would. The center bolts were finger loose at the beginning of step 2 but not at recheck, though they were looser. Could not tell much difference if any on the last 90* pull. I had to work for those.
Thats what  I was figuring and the man reason I did it that way. If I ever boost up the power from where I am now I will install studs I the single bolt replacement method. I know ARP.'s torque specs are higher than the 77 speced in the FSM, but I would like to know torque is on the bolts with that last 90* turn.
I did not use the tap on the threads. Just was not comfortable with the fit. The bolt went freely into the holes prior to installing head. Then when put in after the head with my fingers covered in oil the still went with just my fingers. So I believe all is good.
Thanks for all the input.
Most of the 6BT and CM550 ISB heads I've done we're at around 140 pound feet to 165 pound feet of torque with the 90° angle torque. This is according to my Snap-on Tech Angle torque wrench.  The readings seem more erratic with new bolts I've noticed also. For a stock build as long as the threads and bottom side of the flange of the head bolts have a nice light coating of clean engine oil and the proper Cummins published torque spec and sequence is followed there most likely will not be any premature head gasket failure. I've probably done over a 100 small Cummins cylinder head and HG replacements and have yet to have a come back for a HG failure.
Per Cummins QSOL CM550 engine manual
it is the same as the FSM.
IIRC it falls into the ±110 range.
Does anyone recognize this? It came in a bag with the intake horn and turbo gaskets. I dont ever remeber seeing one before.
I believe it's for the flux capacitor output to the PTO port on the transmission.
And the scrap copper pile grows a little more.
Edited by dripley
I did not get as far as I wanted today. But got exhaust manifold and turbo on with new gaskets for both. So the exhaust side is done. Still cant believe I have had no frozen or brokem bolts. My turbo has not been off the truck in 13 years.
Tomorrow I work on the fuel side then valve train. We will see how far I get.
20190404_152458.jpg.1f6c71eabc06989dfade39d870d38cb2.jpg<
Not too bad for an old timer...almost there. :kick:I see 2 exhaust manifold studs on there.  Did you run outta $ for the other 10?:broke:
No, I got them all. After talking with a couple folks I decided to do a hybrid install. The 2 below them are the studs also. Those 2 were pain to get wrench on when I took it off so I figured to match top and bottom. I did remove the rear one after picture and installed the stock bolt so I could mount the heater return back to it.
That's certainly not the case you presented before! :nono:  As I stated as you torque from the center out (you need to re-check) the torque PRIOR to the 90* turns, YOU SAID THAT WAS WRONG, YOU said to back off and re-torque, Now you disparage as it's OK for stock engines, I think he has some mods, but not pushing 600hp, SO where does your regime come into play? After a injector upgrade, ECM programing, Quadzilla,at what point does it change?
Edited by Blueox01
There was some initial discussion on re-torque vs re-check.. I think that's been cleared up, yet you're still bringing it up...
I do prefer to break the torque again, but that's technique. If you're wanting to re-torque you DO have to break torque. I never said you can't install it per the service manual. My very first post on the subject even referred to the service manual...
In terms of when to go above stock I would look at the evolution of the task and engines over the years. The 2nd gen didn't have you back off 360° after the initial torque and the boost was in the low 20's. The 3rd gen has you back off the bolt 360° after the first torque, providing a more uniform clamping of the head. The boost on the 3rd gens is in the low 30's. So if the boost is increased to low-mid 30's I would at least use the updated torquing procedure. If the boost is above 40 psi, then I would break the 77 and re-do it. Anything above 45 and I would go to studs.
Speak of what's wrong... who is the one who said to tap the head for Cummins head bolts with 12x1.5? They are 12x1.75.
I admit when I've made a mistake, as with the tap for the head bolt.  No one's 100% right all the time
How many engines have YOU rebuilt? or is your technique from "big twin diesel" ?
I did check torque since I figure it came from the factory that way and lasted 440k and 17 years. If I ever go up on the power I will just add studs later.
It was a bust around here yesterday, rained most of the day and misty for the rest. We will see .
