- Replies 45
- Views 7.5k
Mopar1973Man 12 posts
CAMG3X 7 posts
Bullet 5 posts
Mad Bomber 5 posts
Kinda like having a foxy nurse up real close while taking your blood pressure.
I have a switch to turn on the grid heaters or run the signal through some resistors to fool the ECM. I'm working on another simpler bypass that I hope to install on one or both of @JAG1's truc
If your pressure was fine and then spiked like that...something is blocking the overflow back to the tank or you have the check valve backwards. I would pull the overflow line at the Tee before the c
I have a fuel boss mechanical pump and I had an issue with some debris being stuck in the bypass valve, causing the fuel pressure to plummit. I cleaned it out and put it back together and everything seemed to be as normal around 18psi. Though, today when I went for a drive the fuel pressure jumped up to 45-50psi. Thinking the valve was stuck closed I opened it up to find all was normal. I know I've installed the valve in the correct orientation as well :/.
I'm at a loss at this point, can't figure out why the pressure is so high! Any ideas?
I drove for about 10 miles, how much harm could this have caused at 45psi?
Thanks
