- Replies 20
- Views 4.9k
Electrical is a funny animal....Travels at the speed of light yet takes forever to find its understanding. Causing big head pain eventually creeping to other parts of the body. Enough pain for a day,
At the starter relay check for power at terminal 30, then for power at terminal 86 with the key in the start position then report back. Is this an auto or a stick?
Could be the starter relay in the PDC. Swap the horn relay with it and see if starts, as long as the horn works. They are the same kind of relay. I have the same problem in mine. I hate e
So I just rebuilt my motor got it put back in the truck and everything hooked up. Went to crank it up and it won’t even click the starter. But I am Getting power down to the starter. I also noticed my WTS light isn’t coming on at all. Could they be the same problem? What could be the problem? Thanks in advance!
