- Replies 38
- Views 19.7k
dripley 8 posts
Irie808 7 posts
Mopar1973Man 5 posts
JAG1 5 posts
I've got a tidbit to toss in here... I made a few phone calls and found out from Eric at Vulcan Performance that the 2010+ intank lift pumps are actually pretty good pumps now. For stockish truck you
Just joined the community today. Just replaced my in-tank fuel pump yesterday. Not sure if this helps but here goes some info from my job. Wanting to give my old 1999 24v some love I got a f
My experience with Dodge in tank was very poor. Very low pressure after a years use, about 25k miles. I did mount a booster pump on the frame and ran the two for 3 or 4 years before replacing it all w
Hello,
My truck is a late 1999 Dodge Ram 2500 Cummins 24 valve with 250xxx. I live in the middle of Minnesota. Just to make everyone aware.
I have had an issue with the truck since ownership, that every year my fuel gells up at least once. Last year was the worst, I think like 3 times. Had to use a nip cone and a bunch of cardboard to get the fuel thawed enough to start. I use diesel fuel additives year round (white and gray bottles), and generally more in the winter, including walmart brand 2 stroke oil TCW3 year round.
I have the Fass DDRP with relocation kit on the frame just in front of the tank, with the Beans Diesel sump kit, yes I put a nice hole under the sending unit, that way I can pull and push the fuel to filter assembly. Wanted to do the draw straw but that involved removing the bed. My fuel filter assembly is not the 2001 style, though I do have a 2001 fuel filter assembly that needs to be installed. I think my fuel filter heater is junk on the original one. Back to the question at hand. I want to go to using an in-tank lift pump for winter months. I am not sure if I have an in-tank lift pump from factory, I did unhook a wire from the connector on top of the sending unit but I am not sure if that was just because factory used one style of wire harness.
Does anyone know if there is a good aftermarket sending unit lift pump assembly from a reputable manufacturer? I believe that in-tank lift pumps are better for winter use as it pushes fuel. I was about to have a 750 watt circulation block heater added to my sump to keep my fuel heated in the winter but if the fuel gells then it won't work...
Also, I get 12-14 mpg, constantly year round. I do have an Edge Comp 4x2 settings.
Any help would be nice.
Thanks!
