Just for fun...
I'm not sure if the video came through, but this one's just for fun. This is Skyler Oestrich's (Dynomite Diesel Products) race truck on the chassis dyno at Hunting 4 Horsepower here in North Idaho last Saturday.
Any HP guesses?
Edited by Dynamic
  • Replies 24
  • Views 5.2k
  • Skyler made 1552 hp on this pull.   This truck has run a best of 9.765 @ 137.69 mph. He has been running one of my transmissions all this season. Great young man!
  • As long as you guys will still go to church and not let this take over your whole life it's okay then.
  • psi != power.  CFM = power.  A huge single at 65 psi is flowing MUCH more cfm than a 366 at 65 psi.
It did work.
Are you by sand point?
I'd prefer you were near lewiston
Edited by Evan
Just now, Evan said:
It did work.
This was in CDA.
1221
I'm gonna go with 1850...
1500 hp. sounds like a good number.
I was gona say that auto sounds good
Holy Ship!  That beast sounded good.  I had to crank up the volume and listen to it a few times... I think I need some alone time now :whistle:
As long as you guys will still go to church and not let this take over your whole life it's okay then. :thumb1:
Was that blow off valve?  How much psi? 140
Single turbo (a very large single turbo) with external wastegate, about 65 psi boost.
Ohhh damn.  I was guessing lots more psi than that.
Rule of thumb. For every 1 PSI of boost is roughly flywheel +10 HP
Just the jump from the HX35 to the HX35/40 Hybrid was a fairly big increase of CFM flow. Boost never changed. Still the same 45-47 PSI roughly. I do hit the choke point on a performance tune where my economy tune the choke point isn't an issues at all. Quadzilla give you the ability to tune for your hardware.
7-8 is probably more realistic
Skyler makes well over 1000 hp on fuel alone...at about 65 psi of boost, on a single turbo (and a relatively small one at that). A well balanced system accomplishes MUCH! Dynomite Diesel for the win...!
I meant 7-8 hp to 1 psi
That why I say rule of thumb... Doesn't away fit exactly but gives a good idea of what the person is capable of making. Like @dieselautopower pointed out he's only making 65 PSI but over 1,000 HP to the wheels.
Does he slam the throttle at the end or did it really take that long to spool?
Pretty nuts either way
