is that a head gasket leak
- Replies 49
- Views 10k
sam 14 posts
dripley 7 posts
JAG1 7 posts
Mopar1973Man 6 posts
I'm very happy I'm not in my twenties anymore, where I always wanted to squeeze every last little bit out of anything. On the other hand I'd love to go back when I was in my 20s knowing what I know no
I used some of that bars leak in mine when HG started failing. It did help some but left residue which I think is mostly gone after couple flushes but maybe not. It does not seem to have harmed anythi
Jag1, Donkies, Hmmmm!! Should'a retorqued.
99 dodge ram 2500 turbo diesel. 5.9 24v.
I am curious if this is a head gasket or freeze plug leak. its leaking coolant from back of block. tech reckons plug. That corrosion however looks ominous. Ive been quoted $2600 to repair with removing head etc. the pics are from below. As a complete novice can i drive the truck to another shop for a 2nd estimate.
