New DAP VP44 - Hard Start When Hot?
- Replies 25
- Views 7.5k
Mopar1973Man 5 posts
Octafish 5 posts
Dieselfuture 3 posts
Cronus577 2 posts
Bang on... my Assasin is zero at startup, I have no electric pump, as soon as it starts its at 14psi at idle to just over 22 max. Never needed a priming pump as it will suck a football down a gar
Above 15 PSI mine won't start either. That's why cranking pressure is dropped is because too much pressure will cause over advanced timing. This is why ECM duty cycles the power during cra
Your fuel boss alone will only deliver pressure according to your rpm at cranking which should be around 250-300 rpm if I remember right. And at that you will only be creating around 5-7 psi with fuel
Installed a new VP44 from DAP.
Truck starts lightning quick as it should when cold.
I can let the truck sit for 5 days, nose uphill, starts in about half a revolution as it always has.
So no siphon or fuel leaks.
However when the motor's warm, not so much.
Takes 3-5 seconds but does start every time .
But let it set for several hours, cooler engine, no problem.
Starting pressure with my Fuel Boss is 20 lbs.
Out of curiosity, I put my DDRP back on which also runs around 20 lbs starting pressure.
Same hot start problem with either.
Is 20 lbs too much?
No codes with a good scanner.
Wait to start light normal.
Didn't have this particular problem before the old pump died.
I'm leaning towards a faulty new VP.
Any suggestions?
