Heater core or something else?
- Replies 23
- Views 3.4k
Doubletrouble 7 posts
Mopar1973Man 3 posts
Haggar 3 posts
IBMobile 2 posts
Ran a demolition derby car more than 35 years ago and after first heat had a radiator leak. We used some Copenhagen chew because that’s all we had and got satisfactory results however don’t know how i
My heater hadn't been putting out adequate heat for a couple years now. Been meaning to change it, but recently I had my windows fogging up and wasn't sure what the deal was. This last time my wife an
Here is the filter and housing assembly. I use a Napa 4070 filter replacement. The filter housing is quality and one of the things I really like about the mounting is that two bolts can be removed a
I've had a heater core leak before (different vehicle) so I'm familiar with the signs.
The heater core in my '01 3500 has me questioning it. When I turn on the heater I will slowly get a fog on the inside of the windshield, then eventually on the door glass but I do not smell coolant. If I crack the windows and turn off the heater the fog will go away after a few minutes and leave no slimy film like coolant would.
I don't have any leaks on the floor either. I don't want to do a heater core right now. I would rather accumulate what I need to do the heater core, a/c coil and replace dash board top all at once. Probably about a $500 ordeal. I also don't like to use alumiseal or other cooling system sealers unless absolutely nessesary.
I should also mention that the heater does blow hot air.
Any advise here? Is it for sure my core? Should I try a sealant for a temporary fix for now?
Edited by Doubletrouble
