Did I fix everything?
- Replies 51
- Views 10.1k
Ironforger 13 posts
dripley 8 posts
Mopar1973Man 7 posts
Dieselfuture 6 posts
One trip I took the VP44 went bad, Mopar1973man had one delivered to his house and we installed it at a campground near by. Another time, in Moab, U,T the crank sensor went bad and found one at an O'
Yes Read this to the end because wire to cut changed. I got this idea from older vehicles like Hondas that have a button. I also like the idea of rec on/off and blower itself
I usually check the tires, check the oil, and make sure I have some TP in the door pocket and hit the road.
02 3500 nv5600 2wd quad cab. 233k.
I've been as diligent as possible regarding preventative maintenance, but you know how it is, entropy is a ***** and things go wrong.
Now getting ready to put down some serious miles - long distance cross country driving soon, multiple times this spring and summer from NJ to Florida towing a haulmark 20ft car trailer (approx 7,000 gvwr).
Here is a list of the repairs i've done, as well as some pro-active maint in anticipation of major highway miles.
Is there anything else I should do? Thinking I've got the major failure items covered.. Is there anything else that's know to fail on these 2nd gen 24 valve trucks? Opinions or suggestions appreciated. Thanks!
List of recent maint and repairs (in descending order of failure , most recent first
- May 2020: 233k Fuel filter, Water pump, idler pulley, serp belt & cam position sensor (FWIW: the cam sensor wasn't bad, I just replaced it pro-actively)
- April 2020: 232k Alternator (Also did the W-T ground mod and B+ 150amp circuit breaker ), front brakes
- July 2019: pilot bearing, (bronze oilite) rear main seal, trans input and output seals, trans mount, manual trans filter kit and syncromesh lube (overfilled), clutch kit (southbend stage 2), & 4" stainless exhaust
- Mar 2019: 229k 4 new rear tires, Front shocks (SACHS 310178, love em! I tried bilstiens up front but they were WAAYYYYY too stiff.)
- Dec 2018: 228k: ALL brake lines, brake hoses and brake fluid.
- Aug 2018: 227k BHAF (baldwin PA2820)
- July 2018: 226k: timbo APPS
- Jan 2017: 219k Driver side ball joints, upper and lower, 2 new front tires, differential oil
- Dec 2016: New front wheel bearings (and axle nuts)
- Jan 2016 ALL U joints and center bearing (dana/spicer)
- Nov 2015: Harmonic balancer
- Oct 2015: New high flow power steering pump, rebuild vacuum pump, rear shocks (bilstien B46-1908)
- Nov 2014 all radiator and heater hoses
- Oct 2014: Front suspension components, tie rod ends, idler, pitman, drag link,
- Oct - Nov 2013: Fuel boss mechanical fuel pump and big line kit, fuel filter, front main seal, thermostat
- Aug 2013 213k rear wheel bearings (all) and seals,, differential oil, calipers (all) new rear rotors, e-brake shoes, puke bottle delete, cleaned radiator, killed the killer dowel pin, manual trans filter kit and syncromesh lube (overfilled)
- April 2013 bought truck. 213k.
Edited by Ironforger
