150amp breaker tripped again
- Replies 16
- Views 3.8k
Mopar1973Man 3 posts
Doubletrouble 3 posts
IBMobile 2 posts
Tractorman 2 posts
Popular Days
Typically, the charging system has to work the hardest for a few minutes just after you start the truck. Even without grid heater operation, the starter draws a lot of power from your battery. Once
I agree with @Tractorman that the breaker might be weak. When I was doing the charge line protection part of the W-T mod some members went with a fuse due to certain circuit breakers being of poor qu
Not to long ago I did the w-t ground mod with the 150amp breaker on the charge lead from the alternator to the battery (pass side) and it tripped a couple times shortly after install. On the advise here I disconnected the relays for the grid heaters and no more trouble until yesterday. Grid heaters still disconnected, I fired up the truck to run to town, made it about a mile when I noticed the "check gauges" light and my voltage was down to around 10 volts according to the dash gauge.
Popped the hood and found the breaker tripped, not sure why. Did not have the lights on, a/c was off. Shouldn't have been any major power draw at the time.
