- Replies 50
- Views 8k
Doubletrouble 14 posts
Tractorman 10 posts
dripley 7 posts
JAG1 4 posts
The AC compressor is on and the recirculating air is being dehumidified.
Wise minds think alike, John. Dave Yes. Max ac is the only recirc mode. Ha Ha, did it again. Chicken
I was in a similar situation. I typically use the floor/vent combo almost exclusively. I just like it that way. Unfortunately in the winter, the AC would always run. I simply added a switch to the low
On the dash you can place the a/c on max and it recirculates the air in the cab to continuously cool the same air making the cab cooler in the summer heat.
Is there a recirc setting that does the same for heat in the winter? Or do we have to set it on max a/c setting which blows the hot air from the main vents?
Thought it might be useful on the really cold days.
