No electrical - ZIP. Up a creek without a paddle!
- Replies 19
- Views 2.6k
Tbird9140 4 posts
Dieselfuture 3 posts
dripley 2 posts
Doubletrouble 2 posts
All your comments were spot on. The problem area was in fact the positive terminal on the driver's side battery and/or the cable to the starter itself. I only found this out after paying $650 for a
Sounds like you have a bad battery clamp/cable at the driver's side battery. A bad starter motor will not cause a lose of electrical power in the cabin ( lights, power windows, radio, ect.) but a ba
I would agree with @IBMobile. Hope they just dont want to throw parts at it.
Help!!!! Traveling cross country with truck and car on trailer. Trying to limp home 1500 miles with a badly leaking tappet cover (1 gallon oil leaks out per 200 miles!) Pulled in to get fuel. Went to start truck, heard click then nothing! All lights, dash lights, windows, cabin lights, etc. DEAD! Checked batteries, terminal connections, grounds, fuses, etc. all seemed good. Removed terminals from batteries and reinstalled them. Heard door open alarm so turned key to run. and had dash lights, windows etc. Tried to start, heard click again then nothing. Lost all dash and interior lights, windows, etc. again. Waited a few minutes and dash, interior lights reappeared. Put booster packs on both batteries and tried to start again. Same result, click then nothing. This time however thought I saw small puff of smoke coming from positive terminal of the battery near fuse box. Got under neath truck with key in run position to see if I was getting power to starter solenoid. Could not detect any 12 v at starter. Area under truck quite wet from leaking tappet cover. Could this in some way cause my problem? Towed truck to local diesel repair shop. This being the weekend they can't get to it until Monday.
They didn't know what is the problem. They want to pull starter on Monday and replace it. As I noticed that several wires underneath were wet with oil and missing some insulation (?) I want to suggest replacing these wires first and second run a jumper wire from the positive battery terminal directly to the positive terminal on the starter, this way to check if starter is indeed bad before they pull it. Has anybody out there experienced these same problems or have any ideas on what might be my problem. Would you perform the first two procedures I want to have the shop do before pulling the starter? I really need some help. I really, really need some help/ideas!!!
