2006 Dodge 3500 - MPG
- Replies 20
- Views 5.1k
Mopar1973Man 9 posts
Doubletrouble 3 posts
AH64ID 2 posts
Evan 1 post
I've got my best mpg running both directions on the river. I think gravity is about half from horse shoe bend to Lewiston so numbers are likely not realistic compared to the rest of the world
No. Quadzilla is not a solution being its just a rail pressure box. On common rails you need to flash the ECM with all the core values. Even Jacob Kidd suggested other solutions for Common Rails.
An MM3 with UDC Pro is what I would run. UDC Pro has more tables that can be adjusted and that leads to a better daily driver. The MM3 is the same hardware as the Touch but doesn’t have the
Well my first relaxed trip to Caldwell ID. I know the odometer is off and speedometer is off by about -3 to what is actual speed. Now that being said I know its 125 miles from home to Ontario. Now I filled in Riggins ID that's adds on another 15 miles. From Riggins to Ontario showed 123 miles. The odometer is slow too. All from the 285 tires.
All that said I've hit 21.0 MPG which would actually be higher if the odometer wasn't slow.
The other thing I'm pretty sure this truck is 3.73 gears which with the 285s I'm running the RPMs are roughly the same as my 2002 with 3.55 gears and 245s tires. This combo seems to be great for towing weight.
