- Replies 31
- Views 7k
dripley 14 posts
JAG1 5 posts
Threadzy 3 posts
Mopar1973Man 2 posts
I found a car for dripley and you can be incognito in it. He's selling it for chicken feed.
Wouldn't that be something to show up with at the jobsite.
Just a little update. Work has kept from digging in much but other than Monday she running glitch free for now.
Well after all the nice things I have done for my truck it died today. It has cut off on me maybe 6 times at idle over the past 3 weeks but always started right back and kept going. I gues she paying me back for ignoring her. My scan gauge said there were no codes. I did the key trick and got a P 1694 code. I hooked up a snap on solust to her and it read no codes. Thanks to @Haggar for that and I am going to bring back to you. I tried to connect with the PCM and it wont connect, then the ecm with the same results. Checked the codes again and nothing, no connection. Even reconnected the scan gauge and now it will not connect.
I ruled out the lift pump by hot wiring it because the ECM was not turning it on.. I also have no WTS. I wont start she just turns over. I left the key on for quite a while and never saw the WTS illuminate nor would it start.
I guess the truck is brain dead. Hope its not both of them. What do ya'll think?
