- Replies 17
- Views 2.4k
Mopar1973Man 6 posts
Ravewolf 3 posts
Auto Computer Specialist 1 post
Doubletrouble 1 post
This may be the reason the economy is experiencing a pull back as so many factors are creating uneasy feelings about the future. When Cummins goes to average manufacturers placing their name on the bo
I do. Most corporations now are more worried about the bottom line than integrity. It seems so bad they'll sell their own children to keep things in the red. I remember when I was little that S
I'm not a Cummins parts fan being most parts are NOT produced by Cummins and not worth the money. I've seen failed head gaskets (Cummins HG made by BLK) in under 1k miles, Cummins thermostats (made b
So, I'm still having the P0237 code problem, even after I sent my ecm (which was barely scraping by apparently) to ACS. I ended up shelling out the $499,plus another $165 for the wts light fix. Tried disconnecting the battery terminals to see if it was a ghost from the past, but the codes still won't clear. I tried just removing the quadzilla, and still no dice.
I checked all three wires. Ground is grounding, 5 volt reference is getting power, and the signal wire shows continuity between the ecm connector and the map sensor connector. Wtf am I missing?
I'm seriously considering pulling everything, selling it, and going to a P-pump. Because I'm disgusted with the computer bs already. Seriously, I just spent almost $700 and it's still not happy. I stg this truck is cursed. And I'm probably getting karma back for something stupid a long time ago.
