What oil filter do you use?
- Replies 53
- Views 24k
What oil filter do you use? 72 members have voted
1. What oil filter do you use?
Amsoil EaO80 or Donaldson ELF734917%13
Fleetguard LF16035 (Stratapore)20%15
Fleetguard LF3972 (OEM)18%14
Baldwin BT734910%8
Wix 57620 (NAPA 7620)5%4
Wix 57620XE (NAPA 7620XE)5%4
Purolator PureOne5%4
Donaldson P5586151%1
Mobil 12%2
I use a bypass too!12%9
Please sign in or register to vote in this poll.
What oil filter do you use? Do you have a bypass? If you use more than one kind, list your preffered filter. Trying to see what's the most common. If you use a Stratpore LF3894 just select the LF16035. If you use a Hastings LF608 just select Baldwin BT7349. Here is the data I have on the filters listed. Donaldson P558615 40um @ 98.7%, 20 @ 50% Cellulose
Fleetguard LF3972 30um @ 95% (35 @ 98.7% last info) Cellulose
Wix 57620 30um @ 95%, 20um @ 50% Cellulose
Wix 57620XE 25um @ 95%, 14um @ 50% Glass Enhanced Cellulose
Baldwin BT7349 30um @ 98.7%, 12um @ 50% Synthetic blend
Fleetguard LF16035 30um @ 100% (25um @ 98.7% last info) Stratapore Synthetic
Purolator L45335 20um @ 97.5% Cellulose
Purolator PL45335 20um @ 99.9% Synthetic
Amsoil EaO80 20um @ 100%, 15um @ 98.7%, 7um @ 59.97% Nanofiber Synthetic
Donaldson ELF7349/DBL7349 20um @ 100%, 15um @ 98.7%, 7um @ 59.97% Nanofiber Synthetic
Mobil 1 M1403 10um @ 50% Synthetic blend
Edited by AH64ID
