Lift pump choices with some questions
- Replies 17
- Views 5.5k
Mopar1973Man 2 posts
mrtowman4u 2 posts
Gamble 2 posts
dripley 1 post
I like having information to make educated decisions, so I've been reading as many forum posts from as many different forums as I could find and I've come to the decision that I now have a headache. I've got a few questions that I'm not finding answers for, so it's my turn to ask...Is there a difference in reliability between lift pumps that are externally adjustable for pressure +/- (eg Raptor, AD2 system, FASS adjustable) and those that need to have springs replaced (eg. most other FASS, AD system)? I do like the idea of external adjustability to fine tune fuel pressure. But is the external screw only compressing a spring to increase/decrease pressure as opposed to swapping out for a firmer/lighter spring or is the fuel pressure managed in a different manner?I've seen absolutely no questions or posts discussing the FASS FA D08-95G adjustable standalone lift pump. This is the only fuel pump that seems to be advertised as having a boost compensation port.The idea of connecting the boost to the FP seems logical to control fuel feed based upon demand. Does anyone use this or have any info on reliability of this pump? Does it even work as advertised? Websites all tout that their pumps are "quieter than the competition." That really doesn't tell me much since I don't have any friends/neighbors with diesels to do a side by side comparison with. I guess most important is how loud are these pumps when the engine is idling? Can you still hear the pump running when standing outside the truck?Are there any negatives to NOT bypassing/removing the OEM filter housing even when installing an AD/AD2 or FASS Titanium/Platinum system? Does the fuel pressure still stay well above recommended levels or are people finding the need to upgrade to higher flow pumps?Lastly, with a lift pump that is externally adjustable, what negative effects would there be to using one that has a higher rated output on an engine that is still stock? Say, using a Raptor 150 dialed down for a stock engine with "room to grow." Would a person want to use the higher rated pump if they were to end up running through three filters with modest future gains in HP?I realize that one of the air/fuel separators is the most ideal way to go. Given my current needs and likelihood of only moderate engine improvements in the near future, the available options out there and if money were no object, I'd likely go with an AD2 100. However, my current economic situation is likely going to dictate that I spend between 4 and 500 as an initial investment, so an upgraded lift pump and big line kit first, followed by improving filtration later will be the likely, while slightly more expensive scenario.As far as my needs go; currently stock, 20' boat, in bed camper, sometimes both at the same time, mountain driving, don't like to drive in the slow truck lanes and would rather be passing than being passed when going up those long mountain passes. I don't tow regularly, and the heaviest loads will likely be a bed full of firewood and maybe an 8' trailer as well. Normally driven to/from work empty or with a little something just to smooth out the ride and a light foot on the skinny pedal.I hope all this makes sense and I hope it's not too much for one post. I bought the truck four months ago and it's my first diesel. Thanks in advance for any and all feedback. Craig(Mods, I don't know if this would be better cut up into several separate posts or just the way it is)
