Teardown and Rebuild
  • Replies 1.7k
  • Views 307.6k
  • All done
On 11/6/2016 at 11:28 AM, TFaoro said:
As for pre-turbo, I guess I could build a shield to make the filter suck more from the fender instead of the hot air that comes through the intercooler and radiator.
Hood scoop!  some sort of ram air / cowl induction thing.
1 hour ago, Me78569 said:
shaker hood????
HOOD STACK!!!! Intake style :lmao:
Wouldnt that be cool though?  think about a cable operated 71 charger "air grabber" style?  some fab required... but i can dream.
@Mopar1973Man I think we really need to have a Tim the tool man taylor gif built into our emoijis
Well, my brother wanted to thank me for tuning his truck and get me an early Christmas present....
So this guy should be here this weekend. Maybe I can go over 50% throttle with the tuner up :lol:
Finally made it home and got my intake horn installed. She's a beauty! 65psi just fine with no boots blowing off. I think I might be able to run a 1200us tune on the quad and have decent egts. I tried an 1800us and egts flew to 1700 before I let off. Here's a comparison of the outlet for those curious. The S&B is also 3.5" so I'm running the adapter boot provided.
IMG_20161122_113934456_HDR_zpsloye8uor.j
What ya gonna do with the old horn?
Getting some hard missing on startup in the cold (32 here this morning) so I think I'm going to have to bite the bullet and buy new grid heater relays. Never had a problem last winter, and it starts without loping, but I've got tons of white smoke and missing.
That's no good, you pluggin in?
My trucks finicky, sometimes it'll start up no problem when it's cooler out, other time she puts up a big fuss.
Can't plug in... I'm at an apartment complex while I'm at school, so there's really no way to get power out there. When I'm at home I plug it in every now and then, but even in -15F I haven't had any issues.
What does it do when it puts up a "fuss?"
sorta the same thing as yours, minus the miss. It'll put out a good amount of white smoke and just run a little rough, but that's only when I forget to use the grids and it's fairly cold out.
Yep, I have to agree thier should be no reason to plug in unless below zero. You don't want to spoil them ?
I would look elsewhere for issues.
The grid heater shouldn't even make a discernible difference at 32°F. Heck, I don't even plan on reinstalling mine this winter. HPCR will do better with a pilot, but not at 32°.
Have you messed with crank/idle timing?
I agree, it doesn't NEED it to start, but my philosophy with that is, why make it harder if I don't have too. My truck starts up fine in any weather my area can throw at it, as long as I left the grids do their job. It's when I have MPG mode selected up and fire it off is when she gets pissy haha!
This is an interesting discussion. My truck will generally start better without the grids down to 40 or so. Like if I forget to switch off mpg mode and start it, it will fire off quicker than if I let the grids run. May get just a bit of white smoke, but not the slightly slower/longer cranking I get after the grids run. I guess that's just because of how much they draw on the batteries.... :think:
On a slightly different note, I will plug in every chance I get if temps are below freezing, and I'm even running synth 5w-40. I don't agree with what some say about spoiling the truck and I figure why cause any more wear then necessary on a cold start? I'll save it for those rare times when temps are in the negatives and I can't plug in :thumbup2:
Edited by leathermaneod
It has to be the injectors. It would start fine with the 125's, but now that it has 300's it doesn't like the cold without a grid heater. It's even got higher than stock compression pistons. (I think 17.3:1 but not positive)
Alll cranking and idling timing is left alone by the quad.
That sorta sounds like weak batteries to me. Mine will start in the same amount of time of turning the key weather MPG is on or off. It just starts and runs a little rougher right at first but eventually smooth's out. It definitely is interesting to hear how different everyone's truck reacts to starting in the colder weather.
It certainly could be weak batteries, but I really hope not because they are napa golds and less than 2 years old....at this point, I'm not really concerned because the difference in starting isn't much, and my truck also sits a lot right now so that may play into the equation as well. I agree though, it's very interesting to hear how everyone's truck is different!
I could plug in at home but quit doing that. Great to have quick heat but always in the field with minus weather in the winter. Never have power in the field for plugging in. I've never had an issue starting or rough starts. Has to do with the injectors how fine you get the fuel atomized and grid heater function. Also I'm Not even using grid heaters yet. Not cold enough yet.
