Black flakes/particles in fuel tank.
Might tell the guy to stop with the ATF and add 2 cycle oil instead. ATF is way too high of ash content and can possibly plug injector nozzles.
Am I filtering fuel enough?
True... So do I but, I know for fact the local ones here have had 2-3 times more VP44 failures than I have. Being I'm the person replacing the VP44's for the owners. I'm getting rather proficient at changing VP44's taking me roughly 1.5 hours. Kind of like saving @IBMobile on his camping trip through here... He's completely stock and failed around the 90k mark.
There could be a reason for the black particles. I've seen a few reports where biodiesel eats the fuel level float. I've seen reports of biodiesel just being a dirty fuel and not properly filtered before sale. Then you could have issues with algae from water content of biodiesel.
VP44 PSG5 limitations read/write
You can do a bright box or there is either a relay mod or wire mod. I've never done either because the extra load on the headlight circuit becomes excessive usually causes issues with switches.
OBD diagnostics
I think that what it is. Being I've still got my factory cable in good condition I've never had to replace the cables. Sorry I don't know the size right off hand.
Floor Board leak
Windshield leak... I've got the same problem on my truck. The only way to fix it is to replace the windshield. Mine puddles up on the floor mat and only when it rains. I've rolled over on my back and hunted with a flashlight just after a storm and seen where it's coming in around the bottom edge of the glass. I'vee even got a few along the top of the glass that I can make leak with a garden hose with good force. My glass is already cracked I just need time to replace it. Insurance covers a good chunk.
Dead Pedal (I know it's been done to death but mine seems a bit different)
Maybe... Depends on how long it has been high AC voltage against the ECM. Maybe, Maybe not. Simple way to test is to pull the field lead off the back and go for a test drive. If the dead pedal is gone then the ECM is fine. Not mine... This was another member on the site that shared his experiences. That was also around a 2V AC measure on that diode pack.. I'm in the process of getting diodes ordered for the store on the site. So very soon we'll have rebuild kits for people at a fraction of the cost of replacements.
Diodes are what filter the AC down to DC...
Cleaned your post up for ya... Something not right... Sounds like someone didn't do the rebuild...
Make sure to have it bench tested again before you pay and leave again.
OBD diagnostics
Not mine... Mine are still factory terminals. I've never had to clean mine or remove them but to change batteries back at 2012... So it will be roughly 2022 when I remove my terminals from the battery again. Secret... Keep your terminals damp with engine oil they will never rot.
Headlights very very dim
Be careful I've seen cracked fuses that look good but tested with an ohm meter are open circuits. So check them again wth a ohm meter of test light and verify power is on both pins of the fuse with lights on.
These are just 2 filters just the can of the filter is sitting beside the filter element. Stock filter and my AirDog 150.
Valve Cover Gasket Leak
I'll have to agree...
At what cost of the longevity of the VP44 and injectors. True it will work but typically comes at the cost of more VP44 failures and injector life spans shorten.
Yes, that was done correctly and yes that alternator is shot and doing serious damage to all the electronics on the truck I highly suggest you do not drive it also pull it off now have it bench tested to confirm also. Then when you replace to make sure to bench test the replacement alternator before you leave. Start with the alternator replacement first then test again for dead pedal...
Factory filters are still sold as a 10 micron filter. Even with all the tight tolerance in the injectors and injection pump I would have to disagree with @jlbayes .
Actually the heat sink has nothing to do with headlights. If you remove the panel light fuse that heat would be cold. So if you want to reduce that heat from the heat sink the proper way would replace all the interior bulbs with LED's and ditch all the old incandescent bulbs. Relays will do nothing for that heat sinks. It would provide a slightly more power to the headlight bulbs but most people can't tell the difference. Most of this loss isn't the switch per say but the long run of the ground into the cab and its small gauge wire used. So since I drop the sport head lights which are 60w x 4 bulbs or 240w of burning bulbs divded by 12 volts that is 20 amps of draw. The wire size contributes a bunch of loss to the run. So now jumping ship to 35w HID's x 2 = 70w of burning bulbs divded by 12 that's 5.8 amps of draw. Now there is near nothing for loss on the headlight circuit with the stock gauge. Honestly the relay kit of the HID's removes all the load off the headlight switch any ways but reducing electrical loads has a great impact on voltage loss.
If you dim your panel lights at all the switch will increase with heat too. I keep mine wide open and it stays cool.
Headlight upgrades
Retro Shop sold me the full kit. All wiring and 2 assembled headlights. They are even tested and aimed for you. Just bolt them on and plug them in that all. Really simple to do. All ballast, relays and wiring supplied.
Headlight upgrades
Extremely happy... My Morimoto are street legal. Very precise cutoff of light on low beams. High beams the path is huge I've got at least 50 feet into the ditch on the driverside on flat ground. There is a difference @Me78569 , @jlbayes and a few others did the H1 Mini Morimoto's. I'm doing the D2S Morimoto's which is a much bigger lens and seems to have more light. Here is what I bought... http://shop.retroshop.us/ProductDetails.asp?ProductCode=2G.RAM.RETRO http://www.morimotohid.com/ There is a difference. These are Morimoto not an Amazon PNP kit that most get... These are illegal PNP lighting... https://www.amazon.com/Headlight-Ballasts-Chrome-Housing-Reflector/dp/B0134TX8C0/ref=sr_1_27?ie=UTF8&qid=1509630429&sr=8-27&keywords=dodge+ram+hid+headlight These are a joke... I've gotten that same comments about these just horrid lighting. https://www.amazon.com/Projector-Headlight-Ballasts-Housing-Reflector/dp/B013S17SM0/ref=sr_1_20?ie=UTF8&qid=1509630479&sr=8-20&keywords=dodge+ram+hid+headlight
No. You need to take up the door trim the kick panel by the parking brake pedal needs to be removed. The ground is behind the plastic kick panel near the door. Dodge changed up the headlights. So basically the blubs are power with +12V on the common contact and the headlight switch and dimmer switch control the grounds to the lo and hi. So the ground terminates right near the door hinge behind the plastic kick panel.
Headlight upgrades
Don't bother with sport headlights. Britebox won't do much either. I've already done the sport headlights with relay mods and had all 4 bulbs burning. The path of light is still too narrow and not very bright. Halogen bulbs are big power consumers. Sad part is I ended up replacing the sport headlights in less than 1 year. I highly suggest you just look toward the Morimoto HID's. I know the cost more but you'll be much much happier. Surprising how a 35w HID bulb is way brighter than four 60-watt halogen bulbs burning in sport headlights. https://mopar1973man.com/topic/12306-sport-headlights-installed/ https://mopar1973man.com/topic/12865-morimoto-hids/ (Morimoto D2S)
Wasting your money on filters your changing way too early. You might want to start cutting the can open and looking at the media color. I change filters every 60,000 (not a typo). Here is my last 60k filter... Here is one old pic of my 45k filters... Here is a 15k filter... (Fleetguard)
First off double check your battery terminals and grounds. Being that your reseting the APPS muliple time tend to point back to failing alternator creating issues. I would look at the alternator. I've run across a 3rd Gen truck with the same weird issues but it was the alternator feeding way too high of AC noise to the ECM and creating a bunch of APPS problems. After the alternator was replaced the APPS problem or dead pedal quit. The easiest thing to do is to pull the alternator and have it bench tested for AC ripple voltage.
