Alternator Question
No. It's easy just pull the back cover off and the diodes are held in place with Phillips screws. While your there you can change the brushes too.
Communication issues (& more)
Talk to @dripley he's done the dash top replacement.
Here you go...
Edge Juice
Too much traffic on the bus. So... What I would do is start the truck with just the Edge Juice plugged in leave it idle for few minutes to settle down then plug in the ScanGauge II and it should hook up then.
04 F250 Cummins swap
Be aware EPA laws are changing. You have to install a 2007 or later engine in a 2007 body. Check with your local laws like I got this tid bit from a friend in Boise area. Too many people are cheating EPA laws by yanking out the smogged engines and retro fitting older engines so the laws might be changing nation wide soon. Be aware.
Turbo Upgrade HELP
I'm kind of the same way I hate to spend large amount of money on parts I'm not certain of. I tend to come here and lean on the guys for assistance and helping me pick the right stuff. The neat part is we all learn for each other experiences and know what works and what doesn't work.
High idle problem
We've got the Timbo's APPS here...
Dead Pedal (I know it's been done to death but mine seems a bit different)
I suggest you talk to @Dynamic he's our site transmission guru here. https://mopar1973man.com/forum/173-dynamic-transmissions/
Turbo Upgrade HELP
Listen to these guys they know their stuff. Like myself I'm running a 60/60/12 (HX35/40 Hybrid) for the reason of keeping my exhaust brake. I would gladly jump up to a larger turbo if I had the funds for an inline PacBrake. Just for info value the stock HX35W is a 54/60/12... Just remember the bigger the HP/TQ goals are the lower the longevity and reliability is going to be.
Turbo Upgrade HELP
You also have to remember that the larger the compressor side gets the more load you putting back on your lever.
Tires
I should have a horrid time steering? Nope. 235/85 R16... 235/85 R16 (235mm / 199.75mm) (9.25" / 7.86") - 31.72" tall 265/75 R16 (265mm / 198.75mm) (10.43" / 7.82") - 31.64" tall 295/70 R17 (295mm / 206.5mm) (11.61" / 8.12") - 33.24" tall Could have a lot to do with your tire pressure in the front axle. I run 60 PSI in the front and 40 PSI in the rear. I'm basing my tire pressure on axle weight. I've bolded the stock tire size and you can see the difference in metric and inches both. I'vee just scaled my truck 3 days ago... My 235's are rated for 3,042 pounds at 80 PSI. Front Axle (4,480 / 2) = 2,240 / 3,042 = 0.73 x 80 = 58.90 PSI Rear Axle (2,980 / 2) = 1,490 / 3042 = 0.48 x 80 = 39.18 PSI
Tires
295mm wide, 70% is height... So your 30mm wider then stock. 206.5 mm tall from the wheel. 265mm wide, 75% height or 198.75mm. so as you can see your a bit taller but much wider.
Question about IQUAD gauges with my phone.
I could get you a Quadzilla through the site. I've just become a vendor for Quadzilla products. I'm going to try and get things setup soon for the store. But I can still sell you a Quadzilla.
High idle problem
Dumb idea... Unplug the APPS then run the rest again. I know it will throw an error code and trip the CEL but you'll know if the APPS is the cause. It should default to idle mode and then the high idle should engage. Crazy idea but it might work.
How to import / Export custom tunes in the IQuad App
I've got to upload my Edge Comp look a like tune. I'm pleased with the performance and MPG is nearly the same as my old Edge Comp.
Well I'm in Ontario, OR on a regular basis so you could hook up with me. (208) 315-1470 cell You can catch me in Ontario every Tuesday, Thursday, and Saturday.
Edge Juice
He never even changed the MAP sensor. It's possible the data from the sensor is too low and not reporting real boost. It could be a boost fooler problem of the Edge Juice. This boost fooler failure does happen...
Well if you hook up with me I could program your Speedometer permanently without the Smarty locked VIN problem. I've got a CCD Network tool that allows for ABS speed adjustments. You might want to give me a call I'll be more than willing to do this for ya.
Edge Juice
Well, let's see what happens with time. If that occurred then the MAP sensor is working.
wha'ts missing in this picture.
Just noticed there is a different head on the block. The first gen head has a fuel filter boss on the bottom of the intake manifold. I'm assuming this is a later series 94-98 head.
You might take a peek at my two posts...
High idle problem
Resetting will most likely not fix the problem. The APPS reset just programs the span from low volt to high volt of the sensor. What controls the canceling in the APPS IVS (Idle Validation Switches). On the stock APPS the IVS is controlled by a logic circuit which toggles the idle validation switches when voltage rises or falls below the stated voltage on the tag. So I'm going to bet most likely the sensor is getting tired.
The block is all set up wrong for our purpose. Lift pump hole is forward. No vacuum pump and power steering pump. Oil fill hole is in the #1 valve cover insted of the gear case like it should be. It is a VE pump for sure with no high pressure lines but it also appears to be a non-stand throttle maybe an agriculture version? Intake horn should be one set of hole forward if I'm not mistaken.
High idle problem
Did you adjust the APPS sensor for voltage before? I'm just checking some people do APPS sensor adjustments attempting to resolve other issues and end up creating a new issue because the voltage adjustment should never be made.
slipped my clutch.
I always re-bleed a seal unit way too many time have I seen a sealed unit with air in the system.
