  1. You are Welcome. I'm glad you got it! Install is rather fast for the electrical being the only one wire to go into the dash. The rest is under the hood. EGT probe will take time to drill, tap, and install if you don't have a hole already.
  2. I've been just unplugging mine and flashing just like Nick...
  3. Never had to do anything fancy. Even after my system stand dry for days. Just a mayo jar and jump in the seat and pump the pedal slowly. Never needed the ABS bleeder software, never needed to mess with the combination valve. None of that stuff. Be aware the excess travel is most likely the ABS module running a dumping mode where it dumping pressure to prevent lock up. Even though the ABS light is not on the ABS unit is attempting to resolve a speed issue. This is why I said you need to be able to see all 3 speed sensor in real time. Like my truck was fine on all 3 sensors above 30 MPH drop below 30 MPH the right front axle sensor was dropping to ZERO so if I touched the brakes the truck jump to right and back pumped the pedal for a few second preventing you from stopping then ABS light pops then pedal was normal again. Being the ABS module only has 3 speed sensors you need to be able to watch them in real time then the problem will pop out. This is why I got a classified ad for used ABS sensors... https://mopar1973man.com/classifieds/item/13-front-axle-abs-sensors/
  4. You need a live ABS tool and be able to watch the 3 speed sensors in real time. Being able to see real time data from the ABS module is key to finding out whats going on. Like mine was the tone wheel problem. I see you've replaced them. You might contact @Chris O. and ask him about the ABS code he might shed some light on it. As for bleeding brake system, I've never had to do anything special I use a mayo jar with a piece of vinyl tubing routed into the jar. I do it solo with no partner...
  5. That's why I suggesting looking to get a newer style lever. That a lot of cash for changing out a shift fork cover and the trouble of just removing the entire transmission just for a shift lever... Wow. Could you give me a picture of what you are working with? I would like to see what you trying to work with.
  6. That's a problem I'm going to have to say most likely not. As for changing the shift fork lid it might be possible but is it worth it to pull the entire transmission just for a shift lever? Is there a newer version of what you want that you can buy that has the four bolt tower?
  7. Ahhh... You want to know if the shift lever itself will screw on. As far as what I've seen the towers seem to be all the same thread.
  8. So you just want the shift knob am I correct?
  9. That's a good one. Ummm... Being you dealing with a NV5600 shift handle I'm not sure. Why the need for the NV5600 shift handle?
  10. A friend of mine that owns a Chevy truck as well found out that warm intake air does help in increasing the MPG's. If I'm not mistaken he bought a second air filter box and modified so it was pulling warm air from under the hood for winter operation and working really good.
  11. You can post them up on the site Classified Ads... https://mopar1973man.com/classifieds/
  12. Still even untapped you gain the control of better fueling curve custom fitted to your needs. Then you can set your own timing curve that fits your driving style. That is the problem with all the older boxed tuners like Edge. You basically took the tune they build and had to be happy with it. Quadzilla you can still adjust both the timing and fuel curves for just the CANBus. I'm still currently untapped on my VP44 and running +75HP 7x0.0085 injectors.
  13. Like a long ago Big O Tires had a wonderful MT series tire. This tire is no longer made. In the beginning the tire compound was rather on the hard side and worked awesome for off road use. Then later on back in 1999 or 2000 if I remember right the tread pattern changed some and the compound got much softer and the tires were barely lasting 18k to 25 k miles and being wiped out. This is what that same tire changed into and wear quality is very poor. Even going back more back in motorcycle days we would try and get R compound tires for racing on the streets but the tires would wear away really quick but were very sticky tire and great for cornering. Then when I move on to cruiser motorcycles like the Goldwing I was attempting to get away from soft compound tires and something harder so the tires lasted longer.
  14. Articles > 24V > Engine > Electrical
  15. Easy way to test relays is take a known good relay like the horn which is a smaller relay and swap it with what is questionable if the problem goes away then the relay failed. Like two years ago I lost my A/C relay I swapped it with a known good relay and A/C started working. The next town I came across I stopped in just purchased a new relay.
  16. You might get ahold of @pepsi71ocean and have that added to his article.
  17. You DVM isn't sensitive enough. You need a DVM with a AC scale as low as 2V or 200mV to be able to see the ripple. Regulation of the alternator doesn't matter its the output that comes out of the diodes we are measuring.
  18. Might want to post that stuff up in our Classified Ad area. https://mopar1973man.com/classifieds/ This isn't the old classified forum. It a whole new system.
  19. Interesting theory... Now will the PSG and VP44 tone wheel be considered?
  20. If I'm not mistaken the Quadzilla is powering itself through the ignition lead. Basically when turbo timer kicks in the Quadzilla couples the BATT lead and IGN lead together. As soon as the EGTs are below the set point then the Quadzilla disconnects the BATT lead and the power automatically fails on the IGN lead because the key is OFF. In the technical sense, the fuse should be on the ignition lead.
  21. Actually the draw will be the same as fuse you tap in the cab which IIRC is 10 amp. The Quadzilla passes power through the Battery lead to the Ignition trigger during cool down.
  22. H1 Mini's are considered a basic. D2S will fit as well but you have to shave the shroud to fit the housing. D2S have a bigger lens and wider path of light compared to the H1 mini's. Most of the guys here doing it themselves used the H1 mini's. When I was talking to Retro Shop about the differences he informed me about the lens differences and the light difference. Just depends on if you are traveling long at night or not. Like myself, I travel 300-400 miles a week in the dark highways of Idaho.
  23. I've used a 3/4 to 1/2 NPT then stacked 1/2 to 1/8 brass NPT in that... No problem. You can usee anything that is NPT threads.
  24. Love them... Nice and bright beam is placed on the pavement not in everyone's eyes like crap LED headlights or cheap retro fit HIDs. If I had the funds I'd do it again for the 96 but do just the H1 minis.
