Batteries 12v or 6v
With two batteries I think I've got PD9245 series. I would base the series on what you would have for total load with about everything on. You would want a converter that is large enough to hold up to the full load plus still charge a little on the batteries.
Batteries 12v or 6v
@KATOOM is right these converters are the best I've seen. Really do work good!
Rain leaking inside walls...
Wow! You done an awesome job of repairing the RV. Question how did you seam the fiberglass on the side?
Truck loses power and wires are cut
First thing I can suggest is make sure all connectors are clean, got a dab of dielectric grease, and might cycle each connector 3 times to clean up the connectors. VP44, ECM and your battery cables. Might double check the big connector in the PDC. When you do work with that one be careful tightening that bolt it will strip out really easy!
Batteries 12v or 6v
Just for information value... http://www.progressivedyn.com/pendant.html
Elk City, ID is trapped by landslide
I wish I had a copy of the video they produced in the valley here during the 1996-1997 flood. That was also a 11 on the pucker factor scale.
Grid heater relay solenoids and P1291.....opinions
Might have to monitor your IAT sensor reading...
New truck!!
Way to tell mechanical vs. electric is easy. Mechanical will read what actual pressure is all the time. Electric ISSPro gauge will always sweep the needle full span and return to zero before reading pressure.
Sealants... Touchy topic. I've seen what different sealant have done on my RV. The previous owner used some sort of caulking that as it ages it gets brittle and cracks open and water start to leak behind the fiberglass body (delamination issues). I typically head for 50 year silicone of a good name brand. Just need to prep the area good and clean all the old sealant up. I typically cut a very fine bead and to seal the seam or item. Last batch of caulk that some suggested I used didn't work very well. To me its a trial and error thing on sealants. As for the Eternabond tape. It can also cause issues. Again the previous owner had a water leak issue in the dining area of the slide and use Eternabond tap on the corner to attempt to seal the corner. Sad to say it still leak about year after I bought it. Carefully removed the tape and again cleaned the corner up. The with a fine bead silicone I was able to inject the silicone into the corner gap and seal it up permanently. Like this summer I got to re-do all the corner trims on the RV and the clearance lights.
New truck!!
Looks good to me.
Batteries 12v or 6v
The only thing I can add is when you do put your RV away for winter storage make sure to change the "Charge Wizard" over to storage mode. This is the lowest charge voltage it will give and will keep the batteries charged but less likely of becoming gassy and venting water over long winter time storage.
Get Out Of That Truck & HELP!!!!!!
Yes Sir. Always have been. It is my command central. I can see you coming before you get off the highway. No way to sneak into our place. I should put the camera on my dash some time again and show how many people still pass me even doing the speed limit. Should see the amount of times I power braked and dove for the ditch trying to get get out of the way of a idiot passing illegally. True. Sometimes you got to juggle time factors. Is there enough time to get the people out of the vehicle safely? Do you do something to stop the fire? Is more time needed to get the people out of the vehicle because of entrapment? I typically look to attempt to gain time. I would instantly grab the negative lead and yank it off the battery. That should stop the possibly of fire, not always but it should buy more time. Is the vehicle stable and secure? If not find away to make it secure so not to injury other working or injury the people trapped. Some time all you can do is rely on man power.
No wait to start light
Another way is to see if the P0381 code is present...
Again another great reason to be prepared for anything. You never know what might stop services from flowing into your little community. http://hb.511.idaho.gov/#roadReports?timeFrame=TODAY&layers=roadReports%2CwinterDriving%2CweatherWarnings%2CotherStates
MoparMom was mentioning that we live in a recreational area of Idaho. Right now the weather is foul. The winds are high out of the north and rain is pouring down. If my radio tones go off I'm going out in this foul weather like it or not. It's coming down so hard that the river level has come up over 1 foot and still rising yet. Visibility is even poor right now maybe see solid 1/10 of a mile. Looking towards the north...
Funny you happen to say that. Make sure to have on a fairly good size. Smaller one do work but extremely limited on amount of charge. More or less like having 1 shot in a gun or fully loaded clip. So consider you size when you purchase.
Power problem on 96 ram3500 5.9 cummins
Anywhere that will give a good warranty for a good period of time. Of course price is a factor too.
Fuel problems?
Only if the original owner went back into the dealer under warranty to have a lift pump installed. After about 2004 it was all in tank lift pump retrofit. Thing is, you've got the AirTex in the stock location so I really doubt there is an in tank pump. If so where that AirTex pump is now would have an aluminum block to join the two lines together. Your lift pump lead would hook to another loom going towards the fuel tank. You'll still need to have it flashed again to ensure the right software is installed. Not all ECM are created the same. So you'll need to find one from the same year of truck at least and then take it to a Dodge Dealer. While at the dealer to flash it you'll have to install it just before the flash. Dealer techs can't flash a ECM unless its hooked up. There is like 50 or so different versions of software for every year. Like Federal EPA vs. California, Automatic Transmission vs. Manual Transmission, 215 HP, 235 HP, or 245 HP. Canadian vs. American. So just because you'll find one in the wrecking yard doesn't mean it will work correctly until its flash for the proper software.
Power steering
Preferable that you take the return line for the steering gear box. Typically that is the biggest piece to flush and typically settles the most debris in the steering gear box.
Now... This all being said who said you had to be right there in the thick of things? How about traffic control? How about keeping the person safe? How about helping other emergency personnel? I've done that a time or two where I've identified myself from "Salmon River Rural FD" and started assisting in fire suppression on vehicle fires. Chasing gear and equipment for other crews. Don't get me wrong I'm not superman either. I'm trained for vehicle extrication but my first call after training I couldn't do it. I handed the job to my Chief. We had a teenager trapped in a badly crushed vehicle screaming that he wanted out. It broke my heart and broke my will at the time. I continue to do other jobs assisting other and keeping the scene safe. So even folks with training have issues on dealing with the sights and sounds of people hurting or in need.
Batteries 12v or 6v
It does help but very slow to charge. It's been overcast and rainy here for the last few days and RV is stand out with the solar panels. I was doing sanitizing of the water system and doing long runs of the water pump and running some of the lights. Just the recovery time is longer.
Purchasing my first Travel Trailer need advice
Just use the 5 gallon water containers. I cheat. I added extra tubing to my anti-freeze line so I can just dip the tube in the jug and still use the water pump. I don't have to try and pour the water in the tank. Another way just lay the cube on the container and use its own valve. I would. New RVs typically will have a few runs back to the dealer for repairs for warranty work.
There are module rebuilders. I highly suggest whomever you pick better have a good warranty and turn around time. That what sold me on Module Master warranty was good and a company that is very professional. The problem I heard about ECM rebuilding is there is some parts (chips) that are hard to get some rebuilders can some can't. So in the ECM realm, I would say call around and do some talking to different rebuilders. I can tell you that there is no more new ECM available any longer everything is being rebuilt now.
1994 Dodge Cummins Wiring Maps
1994 Dodge Ram Wiring Map ABS Brake Wiring (4 Wheel) Airbag Wiring Warning Buzzer Wiring Charging System Wiring Instrument Cluster Lighting Wiring Instrument Cluster Wiring Courtesy Lighting Wiring Cruise Control Wiring Data Link Wiring Engine Wiring(Page 1) Engine Wiring(Page 2) Exterior Lighting Wiring(Page 1) Exterior Lighting Wiring(Page 2) Ground Wiring(Page 1) Ground Wiring(Page 2) Headlight Wiring DRL Headlight Wiring Horn Wiring Message Center Wiring Rear View Mirror Wiring Overhead Console Wiring Power Distribution Wiring (Page 1) Power Distribution Wiring (Page 2) Power Distribution Wiring (Page 3) Power Distribution Wiring (Page 4) Power Door locks Wiring Power Mirrors Wiring Power Seat Wiring Power Windows Wiring Premium Stereo Wiring RWAL Wiring Starting System Wiring Stereo Wiring Wipers Wiring ABS Brake System (4 Wheel) Airbag System Warning Buzzer System Charging System Instrument Cluster Lighting Instrument Cluster Courtesy Lighting Cruise Control System Data Link System Engine System (Page 1) Engine System (Page 2) Exterior Lighting (Page 1) Exterior Lighting (Page 2) Ground wiring (Page 1) Ground wiring (Page 2) Headlight wiring DRL Headlight wiring Horn wiring Message center wiring Rear view mirror wiring Overhead console wiring Power distribution wiring (Page 1) Power distribution wiring (Page 2) Power distribution wiring (Page 3) Power distribution wiring (Page 4) Power door locks wiring Power mirrors wiring Power seat wiring Power windows wiring Premium stereo wiring RWAL wiring Starting system wiring Stereo wiring Stereo wiring
