Everything posted by 01_Cummins_4x4
Manual to Auto trans conversion
Can't we just swap the PCM harness for the transmissions? I know I can flash the ECM with a Smarty and load the stock tune for the manual or auto trans, that's what I did on the 99 Cummins 4x4 I had a few years ago. If both trucks are the same year and have the same ABS setup, could we swap ECM and PCM modules in pairs between the trucks? When I did the 47RE to NV4500 on that 99 4WD Cummins I did, I just flashed the ECM with the manual trans stock tune which gave it the anti-stall feature. I'm trying to remember does the PCM control how and when the auto trans shifts via the electronics in trans? Also, isn't there a trans relay in the PDC that I would need for the auto trans? That's funny as when I was shopping for another Dodge Cummins 4x4, I couldn't find anything that had a verified built auto trans and I wasn't going to take a chance on an auto trans truck off of a car lot, that's why I grabbed this 6 speed truck in Dec 2020.
If I remember correctly the HO has higher compression in the engine vs the SO engine. Sycostang67, I'm definitely interested!
My truck has 197k on it. I bought in Dec 2020 and it already had the aftermarket clutch and hydraulics in it. The only thing I've added is a short throw shifter tower kit in it.
I don't want the ratchet shifter as it would cost a lot more money than just swapping out the steering column and shifter linkages, unless someone was selling a used ratchet shifter for a great deal.
24v nightmare
I had my 99 engine, so I'm not totally sure if the 01 stock tune file is the exact same as the 99. A call to Mads would be your best avenue as they would probably know.
I was curious if anyone on here has done the reverse and went from a manual to an auto trans? In my 99 Cummins 4x4 that I used to have a few years ago, I swapped out the auto trans and installed a rebuilt NV4500 that my buddy and I overhauled and installed a brand new South Bend single disk clutch. I kept my ECM and PCM and installed a manual trans stock tune file from Mads with a Smarty and it ran great after that. At the time my left knee had stage 4 arthritis in it and it wasn't liking a stiff clutch at all, so I found a friend that had a verified rebuilt auto trans with paperwork from Baker City, and we spent a long day swapping transmissions and input shafts in the t-cases, and all the other related hardware. I have this 01 Cummins HO factory 6 speed truck now that has an aftermarket clutch and hydraulics (shifts great) in it, and more often lately I'm thinking of finding someone with a verified built auto trans to swap with. My truck has an Industrial Injection VP44 pump, 100 HP SAC DAP injectors, S & B air cleaner setup, Quadzilla tuner, AFE intake horn, 4" exhaust system, and an Airdog 150 lift pump, so I don't want to trade the truck for an auto truck unless the auto trans can be verified fully rebuilt and has the same performance mods that I have in my truck. My left knee has been fully replaced in Oct 2018, but I still cannot bend it past 95* since I have scar tissue that's built up in my quadricep muscle right above the knee joint. My ortho doc said that he could give me a chemical cocktail to knock me out and force it manually to bend further at the risk of breaking something else in the process. I know I'd have to swap trans, flywheel, clutch, hydraulics, t-case, driveshafts, pedals, shifters and linkages, steering columns, TV cable for APPS, and probably PCM harnesses. I'm assuming that I'd have to swap the PCM for the auto trans to shift correctly? I guess if both trucks were 2001 with the same ABS setup, could a person just swap the ECM and PCM modules, or since mine is a HO and theirs would be a SO truck, would that not work? Just trying to get some ideas...
24v nightmare
You can flash the ECM with a stock manual trans file from Mads with a Smarty too, as I did that with my 99 Cummins that I swapped a 5 speed into.
2nd Gen Cummins heater temp differences between trucks
When I replaced the heater core and evaporator core in March of 2021. I thoroughly cleaned the inside of the HVAC box. I don't park anywhere near trees and mostly I park my truck in my climatized shop.
I pulled into my shop right after driving 20 miles home from work and left my truck idling turned the heater on high and probed the heater core hoses again. Hot side was 194* and the return side was 182*.
Just as soon as I got home and parked my truck in my shop, I popped the hood and scanned both heater hoses headed towards the heater core. The inside hose which is going to the driver's side tube of heater core was at 178* and the outside hose going to the passenger side tube of the heater core was at 172*. I have a brand new heater core, brand new NAPA 190* t-stat, brand new water pump, and brand new radiator that is clean (new looking on the inside with no scale and new looking on the outside). New antifreeze was installed when replacing the head gasket and t-stat a couple months ago. I don't see how the heater core could be plugged up with all new components.
That's the video I watched when I installed their transposer, and recalibrated my actuator.
@Tractorman - How can I check the temperature blend door for full range of motion? I already calibrated the actuator per the heatertreater.net website when I installed their transposer. I'm not pulling the HVAC box out to check it, so do I need to cut a window in the HVAC box to verify that the blend door is moving all the way in both directions, and then fabricate a cover to fit over the window that I cut into the box? I have a problem with the AC on this truck as well, in that it won't blow cold for very long and it turns to lukewarm air even with a brand new evaporator core, vacuumed down properly with no leak detected and then 2# of R134 injected into the AC system. Thanks, Doug
I'm running a brand new NAPA 190* t-stat. I installed it at the same time I installed a new Fel-Pro head gasket and head studs. Running down the road my temperature gets to 190* when it's fully warmed up.
Right after I shutoff my pickup in my shop I used my infrared thermometer to see what my heater hoses are at. The hot side towards the engine was 177° and the return hose was at 142°. I didn't think to check them until after I shut it down.
I recalibrated it according the instructions that come with the heatertreater transposer. I did the same thing with my Dad's 02 Cummins after I put a heatertreater transposer in it.
In the two previous 99 Dodge Cummins 2500 4x4 pickups that I had, once I replaced the heater core, evaporator core, cleaned the hvac box, new 190* thermostat, new blower fan motor, both of those pickups would roast me out of the cab if I ran the heater on high for too long. On this 01 Cummins 4x4, it has a new radiator, new water pump, new heater and evaporator cores, cleaned the hvac box, new heatertreater transposer for the temp blend door, new blower motor rheostat, and new NAPA 190* thermostat. The only thing that I haven't changed is the heater blower motor on this pickup, but I have good airflow and my engine temp is running 190*, but this truck will not roast me out when it gets too cold outside. I just installed a geno's garage winter grille cover over the radiator, condenser, and intercooler, but that didn't make it do anything different and the truck still runs at 190*. Anyone have any other ideas to fix this issue? I know this is a very common issue in the 2nd gen dodge pickups and hopefully someone has some ideas as what to do next to fix it. Thanks! Doug
Throttle linkage stuck at idle - cannot accelerate
I'm trying to remember for sure, but I think the throttle cable could move a little bit last night when I pulled into my heated shop, and it was the throttle assembly that the APPS is connected to that was frozen stuck until it thawed out in a couple minutes in my shop. Is there any lubrication needed on it?
The throttle cable isn't binding at all - it's smooth like normal. Which lubricant is best to lubricate it?
I just thought it was super weird since I've never heard of it happening before, and I never had it happen to either of my 99 Cummins that I had before.
I forgot to change it obviously, but it's updated now. I just checked the throttle cable by pushing the throttle linkage to full throttle by hand and then worked the throttle cable back and forth. It feels smooth all the way back and forth without any binding at all. I wonder if having the APPS cover over it is just enough barrier from the extreme cold to keep it from getting direct ambient cold temperatures directly to the throttle linkage itself, cruise control cable end, and throttle cable end?
I have a 6 speed NV5600 trans
Have you ever had the throttle linkage where the APPS is connected to, ever get stuck (frozen) in -4° weather? Mine did last night at my friend's house. His house is 3 miles away from mine. I started out in 2nd gear and couldn't push the pedal down because the linkage was stuck at idle. But halfway between his house and home I was able to get it to move a little which brought me up to 2,300 rpm, so I shifted into 3rd gear and drove home at that rpm. When I got it in my shop within a couple minutes it thawed out and was normal again. I wonder if it did it because my pickup doesn't have the plastic APPS cover on it? I have a brand new Timbo APPS on it that I put on this last Spring. I set it up per the instructions. APPS cover, throttle linkage, or throttle cable needs lubrication? I don't see any frayed ends on the visible cable ends. This is my 3rd 2nd gen dodge cummins and I've never had this happen before.
Rear door mechanism adjustment
I just fixed my driver's side rear door by tightening up the cam plate bolt on the cam plate that operates the upper and lower latch rods. Mine cam plate bolt was almost ready to fall out. Once I tightened it up to the point that the cam plate could still move but it was tighter, then I could open the rear door like normal again.
Quadzilla Adrenaline with iQuadBT from DAP
Unfortunately I don't have an exhaust brake, but wish I had one.
What is the typical high idle delay setting set at? Leave warm up mode set at 120 F? Does the Adrenaline need to be set on PL 00 for the high idle and warmup mode to work? Thanks!!!
