Everything posted by 01_Cummins_4x4
Pump code P0216 is gone, but now a slight intermittent engine flutter at idle
I got an Oregon Fuel Injection pump and paid extra for it because it comes with the wire tap - tuner ok warranty. This pump comes with all the Bosch updates and the latest head assembly to handle the tuner or programmer being attached to it. I installed it last night and finished at midnight. Then this morning I adjusted the valves, and then changed the engine oil and filter. It runs great like normal again now.
Cab Lights
All of the pickups that I've ever seen only have 5 factory halogen cab lights mounted on them. Someone else has done some modifying if there is 6 of them on there. If there's 6 lights, then you'll need to buy 2 sets of the same lights to add the 6th one to the mix.
I was looking online and found Oregon Fuel Injection in Eugene OR has their own Bosch EPS815 test bench/stands to test their pumps. I can get their "wire tap" approved pump for $1,661 + $500 core. I think we need to add them to the vendor list that have their own certified Bosch 815 test facility. https://oregonfuelinjection.com/ Industrial Injection has a 2 yr warranty on their VP44 pumps, but they said they are on a 4-6 week delay for new orders.
I had already suspected the pump as being at fault, but the Edge Comp box has proven to cause certain drivability issues and certain error codes, so I wanted to be sure it was the pump before spending the money on a replacement one. I bypassed the Edge completely and it threw the code again instantly, which I thought it would do so anyway. Which vendor has the best price on an Industrial Injection SO pump?
The previous owner always ran the Edge Comp box on level 4 or 5, so that's where I had it. Tonight I decided to clear the code and turn it down to level 3 when the pickup was cooled off but not totally. It was not building boost and it still threw 0216. So I stopped and shut it off and cleared the code and set the Edge on level 2x2, and so far it hasn't thrown the 0216 code yet. So, could this be a bad wire tap connection since it was defueling in levels 3x3, 4x4, and 5x5? Or maybe a problem with the Edge Comp Box?
On my 01 Cummins it only has code P0216. I turned off my Edge Comp box and cleared the code and test drove it. It was still lacking power when cold (not making boost), and it popped 0216 again. I wanted to rule out that the Comp Box maybe causing the issue. Would I need to actually unplug the Edge Comp box map sensor and plug the OEM harness to the map sensor and unplug the Edge tuner, instead of just turning it off, as a true bypass test to rule out the Edge Comp box causing the timing issue? The previous owner did tell me that he ran it low on fuel pressure from the lift pump once and changed the fuel filters on the FASS 165. Lift pump pressure is 17 - 18 psi constantly, so I know the lift pump is working properly. There is no white smoke out the exhaust either. Once the truck warms up enough, it makes boost up to 43# no problem. I'm assuming that my electronics on my VP44 are shot on the GB Remanufactured Inj Pump from Xtreme Diesel Performance. I read that I could mildly heat up the electronics module on top of the VP44 with a heat gun when the truck is cold and then see if it will product boost pressure with the Edge Comp tuner working on it. If it makes boost in that test, then the electronic module on the VP44 is bad.
IAT Sensor wiring diagnosis
I lucked out on this. Previous owner had messed with the sensor connector and the positive wire pin wasn't contacting the sensor pin. I ended up cutting both wires so that the pins could lock into the connector, and then I connected them back to the two wires. Now my IAT sensor is working correctly again.
My ScanGauge2 is showing my IAT constantly at -40F. I just installed a brand new IAT sensor, with no change. Since it's reading -40f constantly, is that an indication that it has a bad ground wire? I have the IAT sensor trouble code showing until I can get this fixed. Thanks!
Want a 4th gen...
Unless you have a lot of money and spare time for a conversion nightmare, your best bet would be to find a 09-12 Ram with only the EGR and delete it and the EGR cooler. You'll most likely need to run EFI Live on it with a tune on it to keep the CEL off because of being deleted.
241 DHD plastic
It's just a link for transfer case parts. Usually they have them in stock and ready to ship out.
241 DHD plastic
https://torqueking.com/xv4003-1998-2002-dodge-np241dhd-transfer-case-exploded-view/
Different 01 Cummins Laramie SLT 4x4
This truck is a factory Laramie SLT model via the build sheet on the VIN, but it didn't come with the overhead compass, outside temp, and mileage display, auto dimming rearview mirror, or power driver's seat. Is the wiring already in place to add those items plug-n-play since it's a Laramie SLT model? I guess I will need to pull the overhead console down and see if the correct wiring harness is already there, or if I need to start grabbing parts from a pick-n-pull yard.
Wrecked 2000
There isn't a TIPM (Totally Integrated Power Module) on a 2nd gen, only on the 3rd gen trucks, which still have the ECM on the engine as well for the Cummins engine. You have the PCM on the firewall, and ECM on the Cummins engine. The 1500, 2500, and 3500 cabs are the same dimensions - regular cab to regular cab frame, and quad cab to quad cab frame. The frames are the same width, except for maybe the Cab and Chassis model. There was some hearsay about the frames having thicker walls on the 2500 and 3500 pickups, but nobody has proven that theory yet that I've seen. The front suspension is beefier to support the Cummins engine weight, and the Cummins powered pickups use 3" wide leaf springs vs 2-1/2" wide on the gas trucks.
Questions..
The 1500's use 2.5" wide leaf springs and hangers. The Cummins trucks use 3". I don't believe there is a thinner/thicker difference in the pickup frames, just the front suspension parts are beefier to hold up to the weight of the Cummins engine. The cab & chassis models are built heavier after the trans crossmember, so those frames are different. From what I've read the cab should just be a bolt on setup - regular cab to regular cab frame, and quad cab to quad cab frame.
241 DHD plastic
Are you sure that it's plastic? The only components internally that have any kind of plastic like material, is the oil pickup tube inlet screen, and the shift fork pads, but that chunk of material doesn't look like it's from those internal parts. Can you just grab them with a pair of long needle nose pliers, or a 3 finger grab it tool and pull them out through the drain hole?
2013 Ram trouble codes
My nephew never got a chance to see if his turbo actuator was at fault. His pickup would use just a little bit of coolant, but it would never leak it externally, or run any hotter than the thermostat temp. He installed a new coolant recovery tank in case the existing one had a small crack in it somewhere, which didn't make a difference with the new one. The pickup never ran abnormal either like if it had a head gasket issue. It would just barely heat up a little above the normal mark on the temp gauge when you put a load on it climbing a fairly steep grade on the highway. He took it to the 1st dealer, and they couldn't figure out where the coolant was going. They "said" that they installed a new radiator cap on the coolant recovery tank and couldn't determine what it was when they had it for a week. Then my nephew drove it up to Lewiston ID to Roger's Dodge where he bought it, and they had it for 2-1/2 weeks. They said that they did a compression check on all 6 cylinders and didn't see any issue there. They said that they found some exhaust gases in the coolant system, but that it wasn't the head gasket. I told my nephew that it has to be the EGR cooler has a crack in it letting the exhaust gases enter the cooling system. Their tech said that they checked the EGR cooler, but I highly doubt they did. After 3-1/2 weeks of no definitive answer, he traded it in and got a brand-new 2024 Ram Cummins 2500 4x4 pickup.
I know this is sudden but...
I'm sorry that I was only on here intermittently the last couple months. When I traded my 01 Sport SLT HO 2500 Ram Cummins for a 03 Duramax Crew Cab long bed 4x4, that the shady individual who I got it from had made a lot of false statements about it having a rebuilt Allison trans, new CP3 pump, new injectors, new glow plugs, etc. with paperwork, then I find out that all of it was BS lies. I was just getting depressed enough just thinking about having to work on the spaghetti nest under the hood or if the engine or trans was going to blow up and leave me with no way to pay for a replacement. The Duramax wasn't leaving me high and dry yet, but it was going to need the typical tranny cooler lines and steering box replaced, which was going to be around $700 after sending the core in on a Blue Top Steering gear box. At least now that I'm in a better 01 Cummins 4x4 quad cab long bed 4x4 (my favorite diesel), which came with a nicely built auto trans (with paper receipt from trans shop in Bend) and it has all the engine performance upgrades done to it. It will need minor repairs like a steering box due to too much play, and a power steering pump since it's noisy. It needs the following things to make it 100% again. 1. Instrument cluster LED bulbs 2. 190 deg thermostat because someone installed a 180 deg one 3. Heater treater fix (on order) and blend door actuator (already have) 4. Both front seat bottom foam and covers - typical Dodge seats 5. CB mount and high quality coax cable 6. Double din stereo with backup camera 7. Door decals and grille emblem - ordered 8. Replace the trans shift indicator PRND2L 9. Install new headlights with HID headlight bulbs - already have 10. Install under hood LED light kit - already have 11. Install Pos and Neg bus bars for better management of powering up accessories 12. Replace bad fuel tank sending unit - ordered it 13. Buy and winch bumper and winch 14. Install grid heater solenoids and cables to grid heater - previous owner deleted them 15. Fix minor engine oil pan leak Mike, if you need any assistance with the website or store, please just let me know, or if you just need to talk about your day, I'm here to listen Brother. My Dad passed away Jan 2019 from a brain cancer tumor that grew back in 5 months after it was removed at OHSU. I wouldn't wish cancer on anyone ever.
Air leak Hard start in the morning.
I had a new FelPro 9522PT with new head studs and it failed within a 1k miles, but I think it was too much timing on the Quadzilla tune that I was running at the time. I swapped over to a Cometic MLX head gasket # COMC5855-067. I didn't have any more issues after that.
Those were pics the respectful young man sent me of it. I tried the skateboard thing as a teenager, and always found small rocks to have it buck me off. I drove down to Bend and back last Sunday for the trade.
After I had a stent installed in my heart Nov 8th, 2023, I lost some muscle strength in my legs, which resulted in my left knee (7 surgeries) not liking the heavy aftermarket clutch in my 01 Sport HO 6 speed. I traded it for a different diesel 4x4, but I just traded it for this 01 Ram 2500 Laramie SLT long bed 4x4 with 4-wheel disk brakes and 4-wheel ABS. It has an actual 195k miles on it from the vehicle record I paid for, which shows the same number of miles on the odometer. It definitely hits a lot harder than the other 3 Cummins 4x4 trucks I've had before. It It has the following upgrades. 1. FASS 165 lift pump 2. Borg-Warner 364sxe turbo 3. Aftermarket air filter 4. 4" exhaust 5. Edge Comp box tuner 6. Head studs 7. OEM Cummins head gasket 8. OEM Cummins valve seals 9. Power Stroke Products cylinder head 10. 5/16" push rods 11. Xtreme Diesel Perf P 108# valve springs 12. Xtreme Diesel Perf VP44 13. 150 hp injectors 14. New Starter 15. New built $4,400 auto trans 11/23 with paperwork 16. Crossover steering 17. Traction bars 18. Limited slip rear diff 19. New ball joints & wheel bearings 20. Aluminum radiator 21. MESA keyless entry with remote start 22. Custom LED tail lights 23. Mishimoto trans cooler 24. Kenwood deck with amp and all new speakers and subwoofer box under rear seat 25. 4" suspension lift 26. Rear air bags 27. Aftermarket exhaust manifold - haven't looked at it yet to see which one it is. 28. Glow Shift gauges for boost, fuel, trans temp, and EGT At least now that I'm in a better 01 Cummins 4x4 quad cab long bed 4x4 (my favorite diesel), which came with a nicely built auto trans (with paper receipt from trans shop in Bend) and it has all the engine performance upgrades done to it. It will need minor repairs like a steering box due to too much play, and a power steering pump since it's noisy. It needs the following things to make it 100% again. 1. Instrument cluster LED bulbs 2. 190 deg thermostat because someone installed a 180 deg one 3. Heater treater fix (on order) and blend door actuator (already have) 4. Both front seat bottom foam and covers - typical Dodge seats 5. CB mount and high quality coax cable 6. Double din stereo with backup camera 7. Door decals and grille emblem - ordered 8. Replace the trans shift indicator PRND2L 9. Install new headlights with HID headlight bulbs - already have 10. Install under hood LED light kit - already have 11. Install Pos and Neg bus bars for better management of powering up accessories 12. Replace bad fuel tank sending unit - ordered it 13. Buy and winch bumper and winch 14. Install grid heater solenoids and cables to grid heater - previous owner deleted them 15. Fix minor engine oil pan leak
The Cummins is back.
Your pickup looks really nice, but I still like the copper shaded color you had on it better. I know you didn't have a choice because it was discontinued, which is a shame.
PCM role
I'd have to look again, but like 190k 2001 factory Ram Sport 2500 HO 6 speed long bed 4x4 with 3.54 gears and a factory limited slip Dana 80 rearend. It has the following. A $10k new paint job in August 2023, with a new steel cowl hood, visor, new windshield, new Mopar rear tinted slider window, etc. I can show the body shop paperwork as proof. New Mopar authentic Sport OEM replacement decals New door seals Newer 35x12.5R17 Maxxis Razr MT tires and aftermarket wheels Dash cover installed from previous owner before I bought the pickup in 12/2020 Edge Juice with Attitude CTS2 Industrial Injection VP44 pump. Airdog 150 lift pump system S & B air cleaner AFE intake horn 100 HP DAP SAC injectors 4" exhaust system Aftermarket performance clutch system 4th gen steering linkage Bilstein shocks Redhead steering box BD diesel adjustable Trac bar Thuren front lift coil springs New heater & evaporator cores New blend door actuator Heater treater blend door fix Pioneer double din stereo with remote Compustar keyless entry, with alarm and remote start capability. Head studs Cometic MLX head gasket with new valve seals and head was decked at machine shop New radiator, water pump, t-stat, and clutch fan. New high side A/C line with orifice tube. New driver's side bottom seat foam and cover New front adjustable control arms and alignment. Newer 4th gen style towing mirrors. No Christmas tree lights stuck on in the instrument cluster. I'm keeping my winch bumper and winch unless the trade has them on it as well. I have a stock chrome front bumper to put on it.
PCM role
I'm trying to remember if the PCM has anything to do with the security/keyless entry, or is that all handled by the CTM? My left leg/knee cannot handle the performance clutch in my 6 speed 4x4 anymore, so I need to find a built auto trans to swap for or try to trade my pickup with its complete brand-new paint job for an auto trans pickup that's had the trans rebuilt.
His pickup only has 100k miles on it, and it's been well taken care of inside and out.
2nd Gen Cummins heater temp differences between trucks
I tested it again with the temp gun at a 45* angle like you suggested, and I got to 160 temp. Now here's another question for you all. Since selecting "Max AC" mode while in full heat, my blower motor spins much harder and faster, resulting in excellent heat output, like way hotter temps. It's not beneficial to drive in the humid or middle of winter on recirc air obviously, so having to switch it from Max A/C to defrost or defrost/floor blend, is more cumbersome. I've never heard of it done yet, hence this question. Is there a way to modify the heater blower motor to blow as hard as it does on Max A/C, and to have it blow that same amount on the regular "outside air" heat modes?
