Everything posted by 01_Cummins_4x4
Quadzilla Adrenaline with iQuadBT from DAP
Where at in the Quadzilla settings do I turn on the high idle functionality? It was 28 deg this morning and it would've helped it warm up faster.
To rebuild or not to rebuild
If it doesn't have any blow by, has great oil pressure, and runs good, then I'd just add some conservative mods/upgrades to it and run it. I've heard of other Cummins owners with more miles on their engines than what you have on yours, and they are running all sorts of power mods/addons and haven't had any issues with them so far.
Who likes Bilsteins?
Do not get Monroe Reflex shocks!!! My pickup had them on it when I bought it in Dec 2020. The front shocks had a date of install of Feb 28, 2020 and both the front shocks were blown out when I bought the pickup. When ever I hit a major bump in the pavement, the front suspension would bottom out on the bump stops. I found a set of 4 Bilstein 5100's for my pickup for $143 shipped from a guy 200 miles away. I pulled the Reflex shocks off and when collapsing them by hand, they wouldn't even rebound at all.
I created a new profile and now I see the settings to modify :-) I have settings set like posted above and then 13, 19, 23, 27, 29. On the Boost Level fueling Canbus do I start at 95% for 0 psi and work up in % for each psi column, and then 125% is in the 10 psi column?
Do I have to create a new profile or load a V2 tune on it before finding the settings you mentioned?
I finally got my Quad installed this evening after work. Right now it's on its level 4 default profile. Like I stated before I have never messed with a Quadzilla tuner before, so this is all new to me compared to an Edge Juice with Attitude tuner. Where do I find these settings to modify that Threadzy posted; Load timing offset 2 Low timing reduction 5 timing scaling 50% Light throttle timing 2 light throttle load 30% Timing scale 15,19,23,27, 29 Mike starts his on 13 with a manual. It runs pretty good right out of the box, but I know custom tuning it will be a night and day difference. Also, my Fuel pressure, EGT, and turbo boost pressure are only on my A pillar gauges, and not monitored in the Quadzilla. Will that be a problem? Thanks, Doug
I followed the XOTIC installation instructions exactly and noticed there was no mention of a retorque needed on the head studs. So I emailed them and asked if the studs needed any retorque, and they said "if you follow the instructions exactly, there is no need for a retorque". I do have to install my marine valve cover on my engine once I get it painted and cleared, so I will most likely check them anyway while I have the valve cover off.
Since I already have ISSPRO Boost and EGT gauges and wiring, I ordered a new ISSPRO Fuel Pressure gauge and wiring kit from DAP, as well as, a Glowshift 3 gauge pillar pod to house them in. I just got my pickup up and running this last Saturday night at 11:05 PM after installing a new head gasket, new exhaust and intake manifold gaskets, NAPA t-stat, XOTIC head studs, new coolant, oil and filter. Yesterday I installed the Redhead steering box and the heater treater blend door transposer fix. As soon as the pillar pod shows up, I can remove the older Edge Juice w/Attitude and install the Quadzilla Adrenaline in it.
Thanks for the valuable info Threadzy! I still have a nice set of EGT and BOOST gauges in a 2 pod pillar mount, but will want to get a matching fuel pressure gauge and a triple gauge a pillar pod mount. They are ISSPRO gauges.
I just bought the Quadzilla tuner with a new fuel sensor from DAP. I noticed that there's a brass valve that came with the fuel sensor, but I haven't looked at it enough to know what it's for yet. I've only ever installed and used the Edge Juice with Attitude on my Cummins pickups, so this is a totally new and foreign tuner to me. I'll be removing my older (most likely first generation - silver display and smaller screen) Edge Juice w/Attitude tuner that is currently on my pickup when I bought it last December and installing the Quadzilla. I plan to hopefully install it with the module in the cab if possible to minimize any Bluetooth issues with my Android tablet that I will be using with it. Is the stock tune good enough to start out with? My engine is stock with the HX35 turbo and NV5600 trans with aftermarket clutch setup, except for S&B air filter system, AFE intake horn, 4" full exhaust, and 100 HP DAP SAC injectors. I'm installing a new Fel Pro headgasket, XOTIC head studs, and new NAPA t-stat just as soon as I get my head back from the machine shop either tomorrow or Friday. I was thinking of installing some gauges on the left a pillar so that I can monitor boost, trans temp, etc., but wanted your thoughts on this setup, and any advice as to where to start with tuning on the Quadzilla, or if someone already has a tune that will work with my mods and trans.
DAP Quadzilla
Do we as forum members still get a discount on the Quadzilla Adrenaline? I cannot find anything about it lately to verify the discount, or the small percentage that goes to help with the forums here. Thanks!
How long do you think the used truck market for good 24 v 5.9 Cummins 2 nd gens will hold out ?
Another aspect of climate change, is all of the forest fires that are burning so huge and hot that they create their own weather pattern. Here in Oregon with the Southern Oregon fire this summer burning over 400k acres, it was nothing but smoke in the air 24x7. The NE Oregon fire was burning at the same time so there was no reprieve from constant thick smoke in the air at all times. I will say this about the forest fires. If the stupid government and liberal tree huggers would let the loggers go in and clear out the downfall and dead trees just to thin that out of the forests, we wouldn't have these huge forest fires that last all summer. We never had them like this when I was a kid, because the loggers kept the forests cleaned up and clear of rapid burning fuel (dead trees and the blown down trees). The spotted owl in Oregon and Washington is not a native bird and was supposedly from Canada. I hunt and fish and believe in wildlife conservation to help manage our herds and ensure that native species can survive in the ecosystems, but invasive species don't need the same protections.
Unknowns Buying A Used Truck
You'd have to be able to look at the torque converter and see if it looks OEM or maybe has any identifying labels or part numbers on it. Pulling the pan might let you look at parts of the clutch packs, valve body, solenoids, etc., to see if anything looks aftermarket there. Look in the pan for any bigger than normal debris. How long has it been since a filter change and refill? It could just be the stuck valve in the valve body causing the delayed 4th gear shift. I've bought a complete 700R4 trans rebuild/upgrade kit from Oregon Performance Transmission before, and they are very knowledgeable and helpful. Look at this kit; https://www.oregonperformancetransmission.com/product/OPT-A518-A618-EL.html
Defective Head Gasket
So which brand of gasket should a person buy if it's not a Cummins gasket? I read Mahle head gaskets suck.
Starter quit!
The 2007 and 2008 Cummins share the same ECM model from what I researched, and were prone to have crappy solder joints in them which caused ECM failures. My buddy's 2007.5 all of sudden one day just died on the road. He just had instrument gauges, headlights, radio, and heater controls, but no crank, no start, no fuel pump. I replaced the ECM with one programmed to his VIN from one of the ECM/PCM vendors, and it fired right up and has been running great since.
2007.5 Dodge Cummins 4x4 ST pickup
My buddy with the 2007.5 Dodge Cummins 4x4 ST 1 ton pickup wants to know if I can add factory cruise control to his pickup. He's tired of having to drive it on long trips without cruise control. If it's possible, do I just need to get a new steering wheel and clock spring, and the required parts for under the hood, and add it with my AlfaOBD tool, or does he need to get a TIPM with cruise control functionality built in it? I don't know if there are any aftermarket solutions to adding cruise control to a 3rd gen Dodge pickup or not.
Front end clunk
On my buddy's 2007.5 Cummins 6.7 and G56 1 ton 4x4 pickup, I installed the following last summer on the front end, and it made it steer better than any other 3rd gen Dodge 4x4 pickup that he's been in; Redhead steering box with upgraded bearings Borgeson Universal 000951 - Borgeson Universal Telescoping Steering Shafts Bilstein 33-170794 - Bilstein B8 5100 Series Steering Stabilizers Mopar Replacement 52122362AL - Mopar Replacement T-Style Rod and Link Steering Upgrade Kits Mopar Replacement 68039930AA - Mopar Replacement Pitman Arms Synergy Suspension adjustable trailing/control arms New top and bottom ball joints Then I added trans coolers to his G56 and changed fluids in both diffs, trans, and transfer case. A couple months ago his starter wiped out his ring gear on his South Bend clutch flywheel, so I ordered a new ring gear for it. Heated it up on the Traeger for about 10 minutes and it dropped right on the flywheel. I used my scotch lock gasket remover discs to freshen up the face of the flywheel and installed a brand new pilot shaft bearing, throw-out bearing, and new shift fork. A month and half ago I changed out his whole A/C system except for the evaporator core due to a failed compressor. This summer I just changed his front end with new axle u-joints and the Yukon lockout hub conversion kit.
Head studs
@Blueox01 How are the Xotic head studs working out for you? Any issues?
So is the Cummins head gasket is considered to be the best one to buy nowadays? How do you tell if you are getting the newer revised Cummins head gasket vs the older one that had blow out issues?
Replacing head gasket
Dripley, When you changed your head gasket, did you have any issues with the head - cracks or warpage?
Is the Cummins head gasket still the best/most reliable one to use? Does the updated Cummins head gasket have the same part # as the older one that was known for failing a lot? I know ARP makes great stuff, but I've heard that some people are using XOTIC head studs and have had good luck with them. Has anyone here used the XOTIC head studs and can provide some info about them? My head gasket is just leaking a little bit of coolant from the front passenger side like some others have noticed on their rigs. It's not leaking internally or mixing with the oil, and my pickup doesn't run hotter than 193-195*. I'm going to see if the head bolts are still torqued to specs on those front head bolts, since I bought my pickup in Dec 2020, and haven't looked at the head bolts yet.
Garage Vehicle: Snowman
Vehicle Nickname: Snowman Date Added To The Garage: 2023-02-20 Garage Link: Snowman
Front end popping noise
Check the u-joints in your front axles, in your case the front passenger axle. That shorter axle tends to receive the brunt of the force applied to it in 4wd mode. My buddy's 07 Cummins 4x4 just popped his right side front axle u-joint (brand new two summers ago) just trying to back up his 5th wheel trailer uphill in his yard while he was in 4wd low to minimize clutching his G56 too much at low speeds. Now he just ordered the Yukon free spin kit that I get to install for him when it gets here.
2001 Ram 2500 KeyFOB
If you have a working FOB, then you should be able to program the 2nd one. I did that with a 99 Dodge Cummins I had that only had one FOB when I got it.
Nv4500 getting harder to get into gear
About the only way to see the clutch, is by removing the slave cylinder and put a remote camera through the hole, but you still might not get to see the clutch disk very much.
