Everything posted by 01_Cummins_4x4
Cutting Out Under Hard Acceleration/Above 68 MPH+ 2500 4x4 47re
On both of my 99 Dodge Cummins with 47RE transmissions, in OD on flat ground driving I'd get a slight shudder which was the torque converter shudder that was being felt. When I had the trans rebuilt in both pickups with high quality parts, there was no more torque converter shudder.
Aftermarket keyless entry/alarm
I just got my 01 Dodge Ram 2500 Sport QCLB HO Cummins 4x4 a month ago, and it didn't come with keyless entry. I looked at the CTM and it is the single plug module and not the premium unit needed for keyless entry. I mostly just want keyless entry and an alarm on the pickup, and don't care about remote start since it has a manual trans. I know of Viper, Compustar, and other brands of keyless entry/alarm systems, but which one would be good without breaking the bank.
Engine cranks, but no start.Update........Update to the update........
Check your IOD and the ECM fuses. You might just have a blown fuse.
4x4 indicator light
Depends upon the year of the truck to whether it has a bulb or LED light. My 01 has a LED 4wd light that won't come on when it's in 4wd mode. It is definitely going into 4x4 mode though. I replaced the 4wd indicator switch, and depressed it fully while it was plugged into the wiring harness, but it still doesn't come on with the ignition in the run position. I'm down to chasing the 4wd light wiring for ground and sense wire continuity now.
P0341..Rough Idle...Smooths Out...Lose Tach
Check this article from Mike;
Axle u joint question
Since I don't know if you have a 2500 or 3500 and what GVWR rating is of your pickup, this is what I can provide; https://www.oreillyauto.com/shop/b/transmission---transaxle-16780/cv-driveshaft-axle-16804/u-joints---axle-shaft-19782/ca50218970c9/2001/dodge/ram-2500?q=u+joints+-+axle+shaft Autozone sucks! They don't even seem to know what u-joint is when looking up a search for it.
Hello From Tri-Cities, WA
Welcome to the forums neighbor. I'm in Athena Oregon so I'm not that far away from Tri Cities.
Everyone post a picture of your truck!
I just got this 01 Sport SLT 2500 HO 6 speed with an Industrial Injection VP pump, Airdog 165 lift pump filtration system, 4" exhaust system, S&B air filter system, AFE intake horn, and Edge Juice with Attitude tuner. The first few pictures of it are when I bought it 12 days ago. The last couple pictures of of how it is now with my Reunel winch bumper, 12k# winch, and LED cab lights. Next will be a black non sport grille.
Searching for this emblem
I'd be up for one with the LED to light it up. My buddy might be up for a lit up one as well. He just made a billet custom emblem on his CNC machine at his work. I haven't seen it yet though.
seat belt question
No, IIRC that is the normal operation for the belt to be free for a while and then the solenoid in the seats will discharge and lock up until you open the door again.
Seat belt light stays on when belt is buckled
I pulled the SCTM out and popped the top off it. It looks completely new inside on the circuit board without any visible damage to it. The ball bearing can move around in it's little plastic cage, so that looks normal to me. To my knowledge the front seat belt retractors motors are only for energizing the solenoids for the seat belt. If they have something to do with the seat belt light on the dash, then how would the seat belt retractor sense wire know that the seat belt has been pulled out and buckled? Is this the "Green/Red" wire from my plug that is the "sense" wire? There are no wiring harnesses on the female seat belt receptacles on my 99. How does the SCTM interact with the air bag system? If they are connected, I've already installed a brand new Mopar clock spring on the steering column, so that should be fine. IOD fuse is good, as well as, the seat belt fuse is good. Just trying to figure out why the seat belt light flashes like normal for it's self check during startup, but then it goes solid and stays on constantly until I turn the key to the off position. I don't remember what year the diagram in my thread is from, but obviously it doesn't have the (3) wire plug like my Laramie SLT does with the power seat. My 3 wire plug going from the SCTM to the driver's front seat retractor has these wires; Orange/Black - assuming that is + Black/Green - assuming that is - Green/Red - Is this the sense wire for the seat belt being pulled out? Thanks!
CACA Bluetooth Stereo
Mike, How do you wire up the backup camera part of the harness? What does the red wires tap in to that come off the yellow RCA jacks? Like you said, the instructions they provide suck!
Helllppp!!!!
Check your grid intake heater relays and ensure that the 4 90* elbow electrical connectors are on their posts on the relays. My rear relay had one wire that was off its post, and that was causing the constant P0380 code.
Projector lights finished with demon eyes?
Did you have to bake your headlight housings in the oven to get the clear lenses off, or did you use a heat gun?
IOD fuse is good, as well as, fuse 16 is good as well.
Oops, sorry I didn't look that far up the diagram. I was just concentrated on the solenoid wiring below. Thanks!
Do you happen to know which fuses they are?
I’m wondering the same thing. Do I remove the ball bearing that’s inside it? I read on the Cummins forum one member there fixed his that way. I guess the next thing to do is to verify that the green/red wire has power, and the black/green wire has ground connectivity. I guess I should check for ground continuity from pin 6 of the seat belt control module and the ground point below the left rear speaker where the passenger and driver seat solenoids splice together.
My 99 doesn't have any wiring going to the female socket belt buckle. I only have the 3 wire plug going to the seat belt retractor with the orange/black, green/red, and black/green wires. A while back I tried a jumper wire between the orange/black and black/green wires before, but all it did was lock up my seat belt solenoid. I just tried the jumper between the black/green and green/red wires, but my seat belt light still stays on after it quits flashing.
Is that the plug that goes to the seat belt buckle on the right side of the driver's seat? I think I was looking at the plug for the seat belt retractor that has 3 wires with the orange/black wire in it.
Where is that connector located at exactly? Mine has 3 wires and maybe I'm looking at the wrong one, and it's a Laramie SLT with driver power seat. Thanks, Doug
That looks like a slick little setup for a backup camera and stereo combo.
I'm assuming that I need to jumper the Black/Green (Ground) with the Sense (Green/Red) wires? I only see the one connector going to the driver's seat backrest, and that is the 3 wire connector that's under the driver seat center seat area under the seat frame. Is there supposed to be any other electrical connectors?
Any idea as to which two wires need to be jumpered? Thanks!
My 99 is a Laramie SLT with the left power seat, and mine has 3 wires - orange/black, green/red, and black/green. I need to know which two wires to jumper. Thanks!
