Everything posted by 01_Cummins_4x4
2013 Ram trouble codes
My nephew bought a 2013 Ram 2500 Laramie 4x4 a month ago, that was already DEF and DPF deleted. We are assuming that the EGR might be deleted with block off plates, but the EGR pipe is still on it, we just haven't had time to remove it to check for sure. He's getting U010C and U010E popping up, but no driveability issues whatsoever. He has normal power and boost conditions. U010C is lost communication with the turbocharger control module, which could be the turbo actuator. U010E is lost communication with the reductant control module, but I figured it's because it's been deleted. What is the best tuner for him to buy that would help him out since he's deleted? Thanks!
2nd Gen Cummins heater temp differences between trucks
I think I won even more now. As I was driving it back down the mountain from my family's ranch, I had the infrared thermometer right against the dash vents, on full heat/ high fan speed, and I got 171* max temp.
I finally got my new adjustable control arms and Thuren front lift springs installed. I removed the front lift spacers to get a smoother ride out of the front suspension. I was able to drive it and when it's fully warmed up, I'm getting 150° temp out the dash vents on full heat and highest fan setting. That's like 50° hotter than it was before.
I know that to truly clean a heater core or radiator is via the rod method, but this coolant has less than 1k miles on it. This coolant still looks new, no cloudiness, not dirty looking. I haven't ever done a coolant flush on this pickup, just a drain and refill. There must have been some residual debris that fell into the coolant ports of the block when I was changing the head gasket the last time. I should've just done a coolant flush then after redoing the head gasket.
My Dodge heater core had some debris in it, but the coolant is fresh and clear from redoing the Cometic MLX head gasket and head studs less than 5k miles ago. I flushed it and ran CLR through it 3 times (2hr soak the 1st time), and then kept flushing it both directions between the supply and return lines until there were no more debris coming out. Then I did the poor man's toe-in measurement of the 4th gen steering linkage. I have yet to install my brand new adjustable control arms and my Thuren front coil springs before getting it aligned again. As soon as I can get it fired up again, I'll post the results of the temps. In the FSM, in the heating & air conditioning section on page 24-7 it talks about a diode that might need to be replaced. What is it for and where at in the wiring harness is it located?
Update, but it's with my lifted and TRD supercharged 3.4 5 speed 97 SR5 4x4 4Runner, which was having only warm air despite having a brand new heater core. On max fan speed and full hot on the temp control, the highest temp was 129°. I just flushed the heater core by itself with CLR, letting it set in the core for 1.5 hrs. I blew the core out with compressed air. I filled the heater core twice with water and blowing that out with air until nothing but clean water came out. Now on full heat and max fan speed, I get 165° heat coming out. Now I'm doing the same process with my Dodge tonight. I might just do the process twice on it for good measure.
Diagnose lack of heater core heat output
Mike, if my supply heater hose is not as hot (same temp) as the coolant, what would I look at for diagnosis of that issue?
My 01 Cummins has the worst heater output compared to the other two Dodge Cummins 4x4 pickups I had. They would roast me out of the cab and cause me to turn the temperature down. This pickup I leave on high and it's still not hot like it should be. I've always had a lack of heat and lack of cold AC with this rig. I already put a brand new heater core and evaporator core in it, new NAPA 190° t-stat, new water pump, new radiator, new radiator fan clutch, new blower motor, new hvac reastat, and heater treater blend door adapter. My EJWA says it's running at 190° at full temp while driving it. I timed the factory blend door actuator per their instructions when I installed the heater treater adapter. I went ahead and bought a brand new blend door actuator and will be installing it this weekend. I'm hoping it's just a faulty blend door actuator not allowing the temp blend door to not fully go to full heat or cold positions. Besides doing that, is there anything else I should look at for troubleshooting? I'm going to check the temps at the heater hoses and radiator hoses again to see what they're at when it's at full temp. Thanks!
AMP Research Power Steps
My pickup has the IEM wiring. The driver's side door ajar switch has the tan wire, black/green wire, and the white wire that feeds the power to the passenger side door ajar switch. I patched the passenger power step motor to the white wire, and the driver's side power step motor to the tan wire. Both power steps activate with the driver's door ajar switch because it feeds the passenger side door ajar switch at the same time. At first I was hoping to make them independent of each other, but it really doesn't bother me that they both activate at the same time.
For the driver's side door, I should be able to tap into the Tan wire? For the passenger side door, I should be able to tap into the white feed wire that comes from the left side? Thanks!
How do I remove the door ajar switch so I can verify which wire is hot? I've never changed them in a Dodge yet, only the screw in style in the old square body Chevy's I had years ago.
So, how does the door jamb switch at each door trip the Dome light to turn on then if there isn't 12v power at the door jamb switches? Is it at the CTM? I'm used to old Square body Chevy with a 12v feed wire at each door ajar switch.
I did connect the driver's side power step wire to the black/light green wire, and it doesn't do anything. Which color are the wires on each side that feed to the Dome light? Is it supposed to be the tan sense wire on the driver's side, and the black/light blue wire on the passenger side? How do you remove the door jamb switches to investigate which colors are doing what?
I bought a set of brand new 3rd gen Dodge AMP Research Power Steps and the Tyca Industries 2nd gen conversion kit to mount them on my 01. The magnetic switches that come with the Tyca conversion kit was wired as instructed - solid purple to left door magnetic switch, and purple/yellow to right door magnetic switch, and then the 2nd wires from each magnetic switch went to a known good ground. Neither step is working from them, so I pulled those POS magnetic switches out. For the 3rd Gen Dodges, they use a posi-loc terminal to tap into each door ajar switch at each door - solid purple for left front door, purple/grey for left rear door, purple/yellow for right front door, and purple/white for right rear door. The instructions state that the steps are looking for a "ground" signal to make them work. According to the 01 Dodge ram manual, the left door ajar switch has a tan, white, and black/green wires on that side, with the black/green being the ground wire. Is that correct? It states that the passenger side door has a black/light blue wire, and the black/green wire is the ground wire for that side as well.
Starter blues.
I've heard good things about these rebuild kits; https://fostertruck.com/collections/dodge-starter-rebuild-kits
Door interchange?
I'm not sure what "flag style mount" is, but the mounting areas for the door mirrors will be the same for 2nd gen Dodge pickups - 94-01 Dodge Ram 1500, and 94-02 Dodge Ram 2500 - 3500 all use the same mirrors.
Door interchange?
Yes, the doors are quad cab specific 98.5-02 Ram 2500 and 3500, and 98.5-01 Ram 1500 quad cab pickups. You cannot use doors from a 94-97 extended cab as the lower rear corners are round and not square. Regular cab doors will not work regardless, as they are different as well.
1998 DODGE RAM 3500 5.9 DIESEL TURBOCHARGED PCM
Nobody here on this forum, receives any compensation whatsoever for steering people towards a vendor. The vendor is supposed to give us forum members a discount on the purchase of their products or services because we support them.
Vacuum lines?
One vacuum line should be a little bit longer than the other one, which would go to the shorter metal line on the t-case crossmember.
Scan Tools
AlfaOBD can do a lot of functions paired with the OBDLink MX or MX+ https://www.cumminsforum.com/threads/alfaobd-injector-kill-test-cylinder-performance-test-readings-help-me-understand.2523739/
Here Kitty Kitty Kitty...
As soon as a cougar or any other predator becomes fearless of humans, then it's time to take action, unfortunately for the animal because they are just living/surviving on instinct to find their next meal. If Fish and Wildlife won't do anything to relocate the cougar, then I'd suggest that you buy a hunting license {if you don't have one), and a cougar permit so that you can humanely hunt it. I haven't tried it yet, but I know several people that have ate cougar and they all say it tastes pretty darn good. Once you harvest it, you could get a nice taxidermy mount made from it.
New addition to our family
Great looking dogs! I adopted my BM/GSD mix on 12/31/22. She will be 8 months old on 4/9/23. I named her Piper, and she is such a blessing in our family. The last pic is when we adopted her.
Surging
When my APPS was going out, it was bucking and surging and giving me dead pedal. That was when I initially bought the pickup and had to drive it 220 miles home that way from the car dealership, Of course it didn't do it when on the test drive, only after I bought the rig.
Differential Problems
Yep, clean the obstruction in the diff vent line/cap and you should be good to go.
Tried a set of LED headlights
I need to switch my Sport headlights to LED. My headlight housings are nice and clear, but the halogen bulbs just don't cut it anymore.
