Prowelder
Everything posted by Prowelder
  1. There is a little round tag on the back side of it that tells you what it is. Is will say either 241ldl or 241 hdl.
  2. Light duty transfer case. Don't worry, it's still pretty tough. The heavy duty unit only has a wider chain and a larger tail shaft to make it stronger.
  3. Yep, just 2 wheel drive low range.
  4. That's a wicked warranty!!!
  5. Yeah they are. A lot of AC Delco stuff are good quality though, even their tools. I've got a cherry picker and a set of their jack stands and love them. Plus their customer service is great! Thanks VW, so are all group 27 750cca?
  6. As long as the heater works on things other than defrost? Then it could be a vac line with a hole in it, or the accuator just went bad. They are about $100.
  7. I never said cheap just that I like them!!
  8. That's a good point, they don't leak. But man they are sooo expensive at almost twice the price of anything else!!
  9. I'd love to have a Buckstop, they are sweet!!
  10. Cool deal guys, thanks for the info!!
  11. Yeah if you didn't notice it on dry pavement than your 4wd isn't working... does your heater and cruise control work fine? Just wondering if your vac line has come off the pump?
  12. They're always after me lucky charms...
  13. The street is even worst! At least I've got a yard to work in...
  14. Haha yeah we do. If I had a shop to work in, I would probably build at least one for mine. Maybe more... But right now I've got no place to work except for outside!!
  15. Just look for the yachts out in the distance and you will find it... It will be in the same direction of the end of rainbow.:lmao2::lmao:
  16. I've got a quick question. In what temps would a winter front really help? Like here it's cold, but not that cold that long. I'm not sure if it would really be worth the effort or not?
  17. You talking about the grey plastic thing? What you can do is take some sheet metal screws and screw it up.
  18. Sure we do... It's right next to the coast line....
  19. Well it could have the 241LDL transfer case like mine.
  20. Mine say Load Range E max single weight of 3860 lbs at 65 psi. They are Fierce Attitude MTs in 315/75R16.
